Author Topic: Not a cafe racer project K100  (Read 110397 times)
Offline Skunky
Re: Not a cafe racer project K100
« Reply #125 on: March 29, 2020, 04:12:14 AM »
Small side project. Replace the annoying and let’s face it, notoriously unreliable 4 way connector to the fuel tank and put it in a more accessible location so that I don’t have to remove the sides to get the tank off
* 25BF3BF8-6849-439B-8A43-C9DFED26A23F.jpeg (39.8 kB . 320x240 - viewed 1196 times)
* 40BDA4D2-C2C9-4094-83A5-98BF32CD3BE9.jpeg (44.79 kB . 320x240 - viewed 1195 times)
* EC3EA31B-66FC-4781-B3ED-C9AB3743F677.jpeg (41.27 kB . 240x320 - viewed 1161 times)
* BA5E93EA-3595-4C3C-BB02-1150257EC21C.jpeg (32.56 kB . 240x320 - viewed 1156 times)
* 0A76EC41-05AB-4093-9C4C-240F15CA34CE.jpeg (35.32 kB . 240x320 - viewed 1123 times)
* D7A7ACB4-0978-4DDC-B784-EB4FDA23164B.jpeg (42.29 kB . 240x320 - viewed 1133 times)
* 9304BA97-C076-4CFE-BEE7-390BC8D34585.jpeg (37.3 kB . 240x320 - viewed 1181 times)
* 81A477C3-E4C1-4BE7-B45D-60C5EF8464EF.jpeg (37.09 kB . 240x320 - viewed 1168 times)
* 01846217-811C-4E80-A941-C87CF2DAC7B3.jpeg (34.89 kB . 240x320 - viewed 1170 times)
  • Derby GB
  • BMW K100lt
90 K100lt
Triumph Thruxton 900
Honda CB400F
Offline volador
  • NEEDS MORE CHROME
« Reply #126 on: March 29, 2020, 07:09:14 AM »
Nice work. Just an observation looks like green and yellow are reversed
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline Skunky
« Reply #127 on: March 29, 2020, 07:25:42 AM »
No they are the right way round. Bike starts runs and roars  112350
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline Skunky
« Reply #128 on: April 01, 2020, 04:25:48 PM »
Finished the handlebar upgrade all the switches are wired and working, with the wires running through the bars. I’ve also fitted new levers, master cylinder and brake hoses. The brake switch has been replaced with a pressure switch at the calliper. I have managed to retain all of the original functionality including the self cancelling feature.
A few pictures and a video below.
* 0F82AC8A-D57B-4925-8719-FFBACBA530B9.jpeg (90.71 kB . 640x480 - viewed 1087 times)
* CD867097-FA10-4579-A988-694808ACD579.jpeg (33.38 kB . 432x576 - viewed 1030 times)
* A8F2F273-BB8F-41AB-94B8-DFEAA9AB40AB.jpeg (30.12 kB . 432x576 - viewed 1017 times)
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline AtLarge
  • Not too many bikes. Garage too small.
« Reply #129 on: April 01, 2020, 06:55:28 PM »
Very clean install  112350
  • IA
  • 1994 K1100RS
1973 Honda CL70-K3, 1975 Kawasaki 350 F9-C, 1994 BMW K1100RS, 2023 Honda CRF300L Rally ABS
Offline Texer
« Reply #130 on: April 04, 2020, 05:29:54 AM »
Nice work and result - thanks for posting the great video.
  • Wa
  • 1987 K100rs
Offline milq
« Reply #131 on: April 04, 2020, 11:26:16 PM »
Those switches look nice and clean. Are they made by MotoGadget?
  • Southern IL
  • 1988 K75S
Offline Skunky
« Reply #132 on: April 05, 2020, 02:52:06 PM »
In Answer to Milq and another question asked by sr20clubbie
The switches are not Motogadget just ones from ebay. I wanted to reduce the size of the cables as I was running it through the handlebars. I also decided to only have switched negative reducing the chances of shorts in the switches and lowering the voltages so I used a 4 way relay board and switch the starter, high/low beam and cutout switch through that. I also fitted a changeover relay for the cutout as the cutout switch is momentary. I wanted to keep the BMW flasher unit as I like the auto cutout function as I'm lazy and have been known to leave my indicators on.
The Choke lever is from a Motoguzzi V11. i used all the existing BMW cables but had to make new cable end on the choke. It all works great.
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
« Reply #133 on: April 05, 2020, 06:07:55 PM »
Well done!
Offline sr20clubbie
« Reply #134 on: April 11, 2020, 04:19:29 AM »
Hi Skunky, what brake and clutch levers did you use?
  • Hobart, Tasmania
  • 99 k1100lt
Offline Skunky
« Reply #135 on: April 11, 2020, 05:11:42 AM »
sr20clubbie I used a set which are common on e-bay. However I had to make alterations to make them fit to the switches. I cut off the mirror fixings and repainted. I also did away with the brake light switch and replaced it with a pressure switch on the front callipers.
I was also not sure whether the brake master cylinder would be man enough but it’s better than the oem unit
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline sr20clubbie
« Reply #136 on: April 11, 2020, 05:19:02 AM »
Hey Skunky, thanks for that,I’ll have a look around is there a particular size reservoir that’s needed.
Also where did you buy the choke lever from.
Thanks mate.
  • Hobart, Tasmania
  • 99 k1100lt
Offline sr20clubbie
« Reply #137 on: April 11, 2020, 05:21:18 AM »
I just seen the 7/8th size there.
  • Hobart, Tasmania
  • 99 k1100lt
Offline Skunky
« Reply #138 on: April 11, 2020, 12:31:33 PM »
7/8ths is 22mm which is the right size
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline sr20clubbie
« Reply #139 on: April 11, 2020, 08:50:48 PM »
Hey Skunky, I actually meant what bore size. Most of the aftermarket ones I have seen are 14mm, I think I need a 19-20mm bore size (correct me if I’m wrong) did you get rid of the abs system?
Cheers Paul
  • Hobart, Tasmania
  • 99 k1100lt
Offline Skunky
« Reply #140 on: April 12, 2020, 02:58:19 AM »
Cheers Paul
I have rental bars on mine which have the smaller bore and I changed the rubber on the bar ends to make them fit. You can get indicators for 22mm bars. My bike did not have ABS fitted. But plenty of guys have removed theirs.
Quote from: sr20clubbie link=topic=10301.msg120670#msg120670
date=1586596742
E bay Motoguzzi V11
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline Skunky
« Reply #141 on: April 19, 2020, 07:52:13 AM »
Due to the Pandemic I seem to have a lot more time on my hands lately, So after completing the Handlebar Switches I started looking at what else I can improve.
When I finished the bike in 2017 the mechanic at the MOT centre did not like the rear strip light because when the brake lights are on the integral indicators do not show up. So to make him happy (and keep me safer because he was right) I fitted a pair of mini indicators either side of the rear tail unit. Problem solved.
So why does it still piss me off!. Even after recently fitting bar end indicators I scoured flea bay until I found a light strip where the supplier claims the indicator sections are still visible when the brake light is on and ordered it.
Although slightly thicker meaning I had to make a subtle adjustment to the rear tail piece it actually works. I have taken photos of the old and new lights strips but because of the glare it doesn't look that different in the photos. So heres two pictures that look almost the same  :laughing4-giggles:
* rear light1.jpg (22.03 kB . 540x576 - viewed 930 times)
* rear light2.jpg (69.66 kB . 562x562 - viewed 896 times)
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline Skunky
« Reply #142 on: May 13, 2020, 04:45:28 PM »
As an extension to the handlebar project. I decided to make switch ikon but the print sheet is so big I thought I would make my own tank badges to suit the Skunk theme.
* 3A50E485-E67F-4D7B-9712-BFCF470A08B9.jpeg (97.26 kB . 640x480 - viewed 886 times)
* ADB5B763-4C4E-40BE-A0CC-8FF5CD5ACDFD.jpeg (21.14 kB . 432x576 - viewed 902 times)
* BC1B4AA6-B2E4-425B-83FD-687F732361AD.jpeg (18.23 kB . 432x576 - viewed 868 times)
* 3DBE4639-2A48-40E9-A5A0-43A02E1A359D.jpeg (101.28 kB . 640x480 - viewed 905 times)
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline sj2000
« Reply #143 on: July 05, 2020, 12:58:07 AM »
Wondering if you can draw the diagram of how you connect the switches, could you please take a picture how you connect the brake switches, thanks. The bike looks nice with all modern accessories. 112350
  • Parker, USA
Offline Skunky
« Reply #144 on: July 12, 2020, 03:46:15 AM »
Sorry, I haven't been on the site for a while.
Switches are switches and buttons are buttons. You can replace your existing buttons and switches with buttons which have the same function and therefore you only have to rewire them the same. I chose to put my wiring through the handlebars and decided to make all handlebar wiring negative switching only thereby reducing the number of wires needed to run through the bars. That required low input relay boards and an on/off latching relay for the kill switch. Its not the most difficult thing to do but you have to consider if it is worth it for you.
I love the look of new buttons but I have to admit that they are not as ergonomic as the original switches and did take some getting used to. To do it without relays you need latching buttons for the High/low beam and Kill switch. All the others can be non latching (Momentary) and then its just a case of replacing them wire for wire.
To draw a diagram as I have wired it would probably over complicate it for you. Get a multimeter and a circuit Diagram and have fun with it.
Cheers
Skunk
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline Skunky
« Reply #145 on: August 16, 2020, 02:49:20 PM »
Just another add on. I decided to try a keyless ignition system on the bike so thought I would get one of the Chinese PKE units that you just walk up to the bike and it turns the ignition on. Just to save the effort of messing around with keys. After a two and a half week wait the goods arrived. Unfortunately without the PKE ariel so basically I was ripped off  177381.
Anyway it cost peanuts to by so I shrugged my shoulders and fitted it anyway. Lo and behold it works  4265249878. Its programmable and as I don't like unnecessary noise when I set off for work at 5.00am (The bike is noisy enough  :laughing1:) I have programmed it for stealth mode.
Please see video below
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline volador
  • NEEDS MORE CHROME
« Reply #146 on: August 16, 2020, 04:39:28 PM »
Where's the bike parked? My Chicom decoder app will have it started lickety split...
  • NYC NY
Offline Skunky
« Reply #147 on: August 16, 2020, 05:46:52 PM »
Inside my Garage - Lickety Split! :laughing1: How quaint. I'm seeing hucklebury Finn One of the reasons that it operates in stealth mode. To be honest who's going to steal a 1990 K100  original or bastardised. i'm also shocked to find car jackers amongst the flock  44271
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline volador
  • NEEDS MORE CHROME
« Reply #148 on: August 16, 2020, 07:34:41 PM »
Stealth mode or Garage mode, easy hack with Chicom decoder app with GPS locator function.
Ask this Huckleberry how he feels Stolen!
  • NYC NY
Offline Skunky
« Reply #149 on: May 23, 2022, 05:09:39 PM »
* BMW2022.jpg (55.72 kB . 576x576 - viewed 481 times)
Hi Motobrickers,
I can't believe its been four years since I finished my build, as you can see the bike is still going great and we (me and my beemer) took part in the Distinguished Gentleman's Rideout here in Derbyshire. I can't stress how much I love this bike and how much I learnt from this site, which I regularly pass on to other builders and owners on the Facebook K groups that I belong to.
These are really great bikes and I had the only BMW K out of 200 bikes. There were a few R100's but they are as common as muck these days.
Keep on Building and Keep on riding.
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Tags: 4 pin connector
