Author Topic: Front Brake Pressure Loss/ Pics included...What part am I looking for? 85K100rs  (Read 3700 times)
Offline whiskywaterwine
I am losing pressure to my brakes, there is oil leaking from under handlebars....
I have included two pics.....leaks coming from copper colored bolt hydraulic line....
What part am I looking for?   Maybe just a gasket?
thanks from the great state of texas
  • Dallas-Ft.Worth
  • 1985 K100rs
id replace the 31 year old rubber brake hoses with stainlless hoses and getts new crush washers on the banjos...
What he said, new hose with banjo fitting and new crush washers.
I've had banjo fittings split and leak if torqued to tight.
so not the metal part....but the plastic part underneath it?
Im sorry....banjo doesnt compute with my vocabulary
what part is it ? number?    its leaking from just under the black peice under the metal part.
  • Dallas-Ft.Worth
  • 1985 K100rs
Offline beemuker
the banjo fitting is the metal piece at the end of the hose. it is round, like a banjo head, the washers are over and under it.
  • Panama City, FL
Offline jj4hm
You could probably have some made locally, or you could just order a set of front and rear for some place like Spiegler.  Spiegler will also let you customize them with different colors if you want to look really snazzy.  I'm sure there are other options out there too, but I agree with johnny that it's time to replace the old rubber lines.
BMW K 100 RS FRONT & REAR BRAKE LINE KIT
Part #: S-BM0063
Year: 1989, 1988, 1987, 1986, 1985, 1984, 1983
Remarks: orig. ABS I
Position: Front & Rear
$174.95
  • Minnesota
  • 1991 K100 RS 2004 K1200LT
