Author Topic: Exhaust Suddenly Got Deeper and Fan  (Read 6102 times)
Offline k
« on: August 15, 2017, 08:20:31 PM »
Shortly after I crested some hilly twisties, I noticed the exhaust was deeper. The bike still runs strong, and all cylinders mist water on the header pipes, but the exhaust suddenly developed a deeper tone, not outrageously different, but just different enough for its daily rider to notice. Do mufflers wear out? Did I spring a leak? Did I crack a seam?
While I was squirting water and snooping around for exhaust leaks, I let the bike idle for about 10 minutes. It's about 85 outside. The temp light came on, and I could smell glycol. That never happened before. Quickly shut it off. The smell dissipated, and I didn't see any coolant on the ground. Shouldn't I be able to idle the bike indefinitely? Do I have a fan out?
Thanks for the thoughts.
  • Indiana
Re: Exhaust Suddenly Got Deeper and Fan
« Reply #1 on: August 15, 2017, 08:39:47 PM »
Yes. Check the blades to see if they'll rotate easily by pushing them with a long screwdriver or dowel. Check the electrical circuit using diagrams from this site.
« Reply #2 on: August 16, 2017, 02:53:16 AM »
Easiest way to check for exhaust leaks is to stick a vacuum cleaner hose, set on blow wrapped in a rag up your exhaust pipe. You can substitute compressor air hose wrapped in a rag. Then spray your exhaust with a mixture of water and detergent, if you see bubbles you have a leak.
Offline kris
« Reply #3 on: August 16, 2017, 05:23:37 PM »
How many miles on this machine? It's not inconceivable that something internal in the exhaust let go....
"I got bike fever bad!!"
Offline k
« Reply #4 on: August 17, 2017, 06:46:35 AM »
Kris,
A ton. Really impossible to know.
  • Indiana
« Reply #5 on: August 17, 2017, 09:53:22 AM »
The bike still runs strong, ...... but the exhaust suddenly developed a deeper tone,
Congratulations!  Your bike finally passed adolescence! :clap:
« Reply #6 on: August 17, 2017, 10:55:41 AM »
How quickly they grow up. Bittersweet.
« Reply #7 on: August 17, 2017, 12:57:57 PM »
Kris,
Somewhere, on some forum, there was a chart for figuring K bike mileage by how far down the little pyramids on the brake pedal had worn.  Probably BMWMOA.org but those elitist a**hole snobs banned my cheap arse for being too cheap to pay their idiotic ransom every year.
« Reply #8 on: August 17, 2017, 02:02:41 PM »
Somewhere, on some forum, there was a chart for figuring K bike mileage by how far down the little pyramids on the brake pedal had worn. r.
Well, there's always this thread for preliminary calculation.
Offline k
« Reply #9 on: November 05, 2017, 12:50:28 AM »
Found a large hole in top of muffler.
  • Indiana
« Reply #10 on: November 05, 2017, 01:04:00 AM »
Very interesting. I don't want this to sound personal but I'm sure lots of inmates would love a picture of your exhaust hole, the bricks hole not yours.  :nono
