Author Topic: adjusting for size  (Read 6781 times)
Offline BsSage
adjusting for size
« on: August 09, 2017, 09:55:57 AM »
I have an 85 k100.  Loving this thing but I seem to be a little big.  I am 6.1 bout 212 lbs.  In the most comfortable (for my legs)  position I am sitting on the halfway hump (rider/passenger) part of the seat.  I also seem to be leaning heavy on the handlebars making the fingers on my throttle hand numb.
Was thinking about adjusting handlebars just not sure what to expect from adjustments?  I imagine there is not adjustment for the seat or foot pegs without an investment of money?
The bike is all original mint with 29k.  I really don't want to do anything which cannont be easily undone.
Thanks in advance
Bryan
  • Keokuk Iowa
Re: adjusting for size
« Reply #1 on: August 09, 2017, 11:17:15 AM »
are you sure its an 85... check it here...
is this k100 a standard... c... t... rt... rs... lt..
is it low seat... standard seat...
what bars you got... standard... c... t... rt... rs... lt..
please post some photos...
also... click here for master yoda riding position search...
ride dangerously...
« Reply #2 on: August 09, 2017, 12:04:17 PM »
I have an 85 k100.
Attached is an image of the bike in your first post.
* Brian's 1985 K100.jpg (88.07 kB . 600x450 - viewed 410 times)
If it is the one you're discussing in this post, it has the standard height seat—no adjustment. The handlebar looks like an RT touring bar. It might even be attached to a riser. You can move the dash out of the way by removing two screws then loosen the bar clamp screws and rotate the bar to find a more comfortable position. BMW bars are 22mm, not 7/8" if you're contemplating a different bar. Flanders American Side Road cycles is a good site to visit to select handlebars for BMW bikes. Rise and pull back are two terms that relate to handlebars. The Flanders site has an illustrated explanation of the terms.
Here is a useful site
  • 1995 K75 89,000 miles
Offline BsSage
« Reply #3 on: August 09, 2017, 12:25:20 PM »
Yep that is the one.  According to the regristration it is an RS
  • Keokuk Iowa
« Reply #4 on: August 09, 2017, 12:32:55 PM »
It has been modified to be a half-naked touring bike. Google 1985 K100RS and you'll be seeing bikes with fairings, lower bars, and streamlined windscreens.
Offline ^Adrninistrator
  • Acute Cinnabar Toxicity
  • Brunhilda Baywerische-Motosenwerken
« Reply #5 on: August 09, 2017, 02:14:21 PM »
BsSage:
I am Acute Toxicity, the BMI (Bureau Of Motobrick.com Investigations) Agent In Charge (formerly known as Brunhilda).
It has been brought to my attention by the DMJ (Department Of Motobrick.com Justice) that you violated motobrick.com protocol by not exhausting the Posting Guidance provided to you here at motobrick.com.
You must do 1 and 2 immediately to continue viewing motobrick.com.
A T
  • New Idria California
  • 1997 K 1150 RS SE Dakar Yellow Code 267
If You Are Looking For Trouble. I'm The Woman To See.
If You Are Looking For Satisfaction.  Email Me.  Satisfaction Guaranteed.
brunhilda.baywerische-motosenwerken@motobrick.com
« Reply #6 on: August 09, 2017, 02:17:25 PM »
the handlebars on the thing are very high... i would rotate them down to where your banjo bolt clears the tank... try  that out... and slowly raise them up a little at a time until all is good...
need better photos of how those bars connect to the tree... grip angle is all freaky and just wrong...  it looks like bar back whack...
Offline BsSage
« Reply #7 on: August 10, 2017, 02:51:26 AM »
Laitch  I see that now.  Thanks.  I wonder how much an original fairing cost?
AT:  I did a quick search, must have chosen the wrong keywords.   I am guilty of not spending much time on that.
Johnny:  I rolled the bars back about 1,1/2 inches.  Still seem to be putting a lot of weight on my palms.  Much further back and I will be touching the tank.   Tried to take some pictures but apparently, I have to resize the image's.  I Don't want to spend much money but I imagine I can find a used seat that places the business part of the saddle a little further back.  Not sure what keyword or kind of seat to look for though.
  • Keokuk Iowa
« Reply #8 on: August 10, 2017, 05:04:26 AM »
Is the "leaning" you describe a leaning rearward from wind pressure that pains your hands and arms? I'm around 6'2" with a 35" sleeve length and 34" inseam. My bike has no windshield. My bike's handlebar is both lower and also more forward than yours but I hardly put any weight on my hands and arms at city and highway speeds because when I ride, I use wind pressure as a cushion to support me as I lean forward. That relieves pressure from my hands and arms until I'm exceeding the speed limit.
You'll need to have your seat modified by an upholsterer to get the feeling and position you think you want. The aftermarket has no bolt-on options for the K75 except for products from custom seat builders who use your bike's seat pan as a base. There are aftermarket cushions that might level the surface so you can slide further rearward. If Jack Riepe adapted to this bike and has had adventure after adventure, there's hope for most of us.
The original fairing wasn't exactly a bolt-on option; it was a design system. It and its associated parts could be installed on a naked bike at considerable expense but they are rarely found now.
A side profile photo of you seated on the bike would help clarify your situation. Resizing a photo should be much less effort than changing the handlebar.
« Reply #9 on: August 10, 2017, 05:21:32 AM »
1 set your phone for smaller photos...
2 did you read master yoda...
« Reply #10 on: August 10, 2017, 06:28:43 AM »
These are not Harleys.  They are not designed for sitting back with your feet up.  Sitting forward with knees down is the position.
The upper body position is also more forward lean, with airflow helping support.
Core body strength is a factor.
I am 6ft and ride stock setup k75s and k13s.  Zero issue with pressure on hands, in fact there is almost no pressure at highway speed.
« Reply #11 on: August 10, 2017, 08:16:05 AM »
You can relieve the pressure on your palms by gripping the tank with your knees and using the sphincter muscles in your core to raise your upper body.  This reduces the pressure on your arms and hands, and gives you the advantage of being more "one" with the bike.  There is an article on this site about the Master Yoda position which will describe what I'm talking about.
Offline BsSage
« Reply #12 on: August 11, 2017, 12:15:26 PM »
I kinda skimmed "master Yoda"  But am going to do a deep dive into it now,,before I adjust anything else.
I do have some subtle body quirks.  I ran over myself with a riding mower when I was a kid (another story).  Because of my age and how long I was off of one foot and leg.  My right foot is smaller (9) than my left (12.5) my right leg is also shorter which skews my back.  I don't think that would have any effect riding other than using the rear brake pedal (I am missing my big toe and part of my foot).  Nobody could tell from watching me. It just has a subtle way of sneaking up on my when doing certain things.  Like golfing, (nothing to pivot on) or when I swim, (I tend to swim in big right-hand circles.)
Soo I will read,  I will learn,,
  • Keokuk Iowa
Offline White Dog
« Reply #13 on: August 12, 2017, 10:04:32 PM »
The first mod I had done when I got my '95 K75 was visit an auto upholsterer and had him move the butt hump back and add foam to the low profile dip.  He also recovered the seat and total cost was less than $100.  Caught him on a good day.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Offline BsSage
« Reply #14 on: August 21, 2017, 06:20:16 PM »
Master Yoda wins.
Read his stuff.  Retrained my brain and muscle memory.  Been taking a 15 to 30 mile ride each day.
No more numbness in hands, back is great and I am looking foward to getting on the bike 100 times more.
Thanks
  • Keokuk Iowa
« Reply #15 on: August 21, 2017, 06:51:53 PM »
May the Force be with you.
Yoda to you sends regards.
