Author Topic: K100LT Weak Brakes  (Read 3644 times)
Offline thetailwind
K100LT Weak Brakes
« on: August 08, 2017, 06:23:11 PM »
Hello, I have a K100LT w/abs. I'm in the process of restoring it and I changed the brake fluid. I used a mityvac and have bleed many motorcycle brakes before. The lever feel solid and the rear brake feels solid as well. I slammed on the brakes pretty hard in the way that my other bikes would throw me over the handle bars but this bike brings me to a gradual stop. I have not replaced the brake pads yet and prior to me it had been sitting for 10 years. I've never known pads to just go bad. Is this possible? I have ridden 10 miles intentionally hitting the brakes to see if I could wear any residual film or what have you from 10 years of sitting.
I looked over the soft lines and I have seen no obvious bulging.
Ideas?
  • Maryland
  • 1990 K100LT ABS
Re: K100LT Weak Brakes
« Reply #1 on: August 08, 2017, 07:04:16 PM »
I had a similiar issue with my brakes when I restored my bike.  It turned out that even though I thought I had bled and rebled the brakes there was still air in the lines.
I would bleed through at least three full reservoirs of fluid and try again.
It also is a good idea after that to tie the brake leave back about half way and leave it over night for an residual bubbles to rise to the surface.
Good luck
« Reply #2 on: August 09, 2017, 02:59:50 AM »
Normally vacuum bleeding gets all the air out easily. What is the condition off the discs? You could also try scuffing the pads and cleaning the discs.
« Reply #3 on: August 09, 2017, 05:04:29 AM »
Do you want to be thrown over the handlebars?
