Author Topic: Front brake light switch  (Read 8321 times)
Offline frodef
  • 1986 K75C
« on: September 13, 2011, 09:34:39 AM »
It seems my front brake light switch has become unreliable, I guess because I've left the bike out in the rain quite a bit. Symptoms: The brake-lights don't come on when I press the brake lever, and the triangle warning light tends to stay on even after I've used both brakes.
Any suggestions how to best attack this? I only briefly looked at the lever, and it seems there are two separate wires going to it (in addition to the actual brake line)?
Thanks,
Frode
Re: Front brake light switch
« Reply #1 on: September 13, 2011, 09:50:16 AM »
It's a simple piston switch that can be unscrewed. (Part 61311459569.) Not uncommon for them to get clogged and sticky with dirt or the spring in them fails.
The other wire is a pointless ground.
« Reply #2 on: September 13, 2011, 01:02:19 PM »
Since you are familiar with the norwegian language, this thread may help.
Inge K.
Offline blakey
  • Learn to listen, listen to learn.
« Reply #3 on: September 14, 2011, 08:22:27 AM »
Sorry Inge, didn't understand a word on that thread...oh hang on, I did see WD40. That's how I cleaned mine. Soaked it in WD40 and it came good.
I hope yours is as easy to get working again Frode!
blakey
K100RS 1986 RED!
North of Bris Vegas, Queensland, Oz.
« Reply #4 on: September 14, 2011, 01:34:32 PM »
You should try some Norwegian lessons, it`s far more easier to learn than spelling DeoxIT.
Inge K.
