Author Topic: Fan Not Turning On  (Read 8049 times)
Offline 85-K100-Cafe
Fan Not Turning On
« on: July 24, 2017, 09:03:02 PM »
Hello,
The fan on my 1985 K100RT isn't coming on. I let the bike idle for 10-15 minutes and it did not turn on. All the fuses on the motorcycle are good. Is there a way to pinpoint the issue between the temp sensor, temp relay or a bad fan? I am trying to figure out how can i test each individual part to nail down the issue.
Thanks
  • New Haven, CT
  • 1985 BMW K100
Re: Fan Not Turning On
« Reply #1 on: July 25, 2017, 05:23:20 AM »
Does the overheat indicator bulb light during that interval? Has it ever lit?
http://www.motobrick.com/index.php?topic=5045.0
  • 1995 K75 89,000 miles
« Reply #2 on: July 25, 2017, 05:25:01 AM »
Can you easily spin the fan blades by hand?  It's possible that the fan is seized and needs replacing.
« Reply #3 on: July 25, 2017, 09:47:12 AM »
1st thing i do is jumper 12v to the fans under tank connector to make sure its running and i feel for air flow...
sometimes the motor runs butts blade donts turn...
process of elimination... i go fan 1st and work backwards to relay 2nd and sensor 3rd...
butts im betting it didnt getts hot enough to trigger the fan in that time frame...
« Reply #4 on: July 25, 2017, 10:53:27 AM »
I bought the K as the previous owner was converting the bike into a "café racer" so it doesn't have the factory gauge cluster.
  • New Haven, CT
  • 1985 BMW K100
« Reply #5 on: July 25, 2017, 10:54:08 AM »
I can spin the fan blade freely by hand
  • New Haven, CT
  • 1985 BMW K100
« Reply #6 on: July 25, 2017, 10:55:19 AM »
How do I jump the 12v to the fan under the tank connector?
  • New Haven, CT
  • 1985 BMW K100
« Reply #7 on: July 25, 2017, 11:37:06 AM »
disconnect fan side from loom side... jumper wior from + to connector and jumper wior from - to connector...
« Reply #8 on: July 25, 2017, 12:13:16 PM »
Thanks, will try this tonight
  • New Haven, CT
  • 1985 BMW K100
Offline jakgieger
  • itinerant farmer
« Reply #9 on: July 25, 2017, 05:22:51 PM »
This thread contains the wiring info that may be useful...scroll up for testing options.
  • Kansas USA
  • 1989 K100rs se
