Author Topic: School me on Alternator load light please  (Read 4564 times)
Offline boostd4
« on: July 06, 2017, 02:56:41 PM »
Hi,
I have a 1985 K100RS that someone started making a cafe racer project out of.  I swear through all my reading/searching about these bikes I read somewhere on this forum that the bulb in the instrument cluster was required for the alternator to work properly and that removing the cluster could ruin the alternator.
I bought the bike with no cluster.  It runs normally, I've maybe put 150 miles on the bike since I've had it and it has a stable idle and no symptoms I can discern.
Is there a wire I should have a resistor on?  Am I truly at risk for some kind of electrical failure without the cluster in?  I do plan on getting a KOSO cluster with basic warning light functions (temp/oil/neutral/battery,etc)
  • Chicago, IL
  • 85 K100RS Cafe/Streetfighter project
Re: School me on Alternator load light please
« Reply #1 on: July 06, 2017, 04:35:25 PM »
I swear through all my reading/searching about these bikes I read somewhere . . .
Read these two threads. The first gives you information about the interaction of the cluster light and charging operation. The second gives you an idea of the correct output of a working alternator. You can use a multimeter for the test.
http://www.k100-forum.com/t8912-battery-charging-light-absolutely-necessary#104855
http://www.k100-forum.com/t6817-testing-alternator-output
  • 1995 K75 89,000 miles
Offline boostd4
« Reply #2 on: July 06, 2017, 05:30:45 PM »
Thanks!  Very informative threads.  I joined that forum just yesterday (new to K-bikes).  It seems the concensus is that outside of a working bulb in the instrument cluster, the alternator can be triggered to charge by RPM as well.  Something like 2500rpm and the alternator circuit starts charging (vs immediately or 1000rpm with the bulb there?).
I don't idle my bike ever, really.... I'm riding within 30 seconds and 2500 rpm comes shortly after that.  I can test the alternator if I need to but don't have any symptoms.  Any other risks?
  • Chicago, IL
« Reply #3 on: July 07, 2017, 07:26:28 AM »
You must be on one of those bikes that spins donuts at traffic lights. :giggles
