Author Topic: 87 k75 failure to start.  (Read 4666 times)
Offline mburnley01
« on: July 01, 2017, 09:27:08 PM »
so i have been working on my bike i got it to start just fine but the little green button was broken so the button just dove in ans kept the starter turning. I fixed that part. But now when i turn the key, headlights come on, but no diagnostics. None of the cluster will self check. I tried arcing the tabs in hopes it will turn over. Nothing. The fuel pump is not running. The fuses are all fine. Im at a loss.
  • NW Louisiana
  • k75
Re: 87 k75 failure to start.
« Reply #1 on: July 01, 2017, 09:49:26 PM »
.  .  . but the little green button was broken so the button just dove in ans kept the starter turning. I fixed that part.
What was wrong with the button and how exactly did you fix it?
Offline mburnley01
« Reply #2 on: July 01, 2017, 09:57:37 PM »
I drilled a whole in what was left mounted a spring and stuck a washer on what was left and epoxied everything together.
  • NW Louisiana
  • k75
Offline mburnley01
« Reply #3 on: July 01, 2017, 10:48:31 PM »
Sorry, the top of the button was broken off when I got it. The spring was also gone.
  • NW Louisiana
  • k75
« Reply #4 on: July 01, 2017, 11:25:03 PM »
You can see that the assembly is more complex than a washer. I think you'll need to find a replacement switch or fabricate parts that you can see in the following posts.
https://www.motobrick.com/index.php?topic=9094.0
http://www.k100-forum.com/t6814p50-1987-k75-cr#123201
Offline mburnley01
« Reply #5 on: July 01, 2017, 11:43:21 PM »
Thanks! I'll take a look.
  • NW Louisiana
  • k75
« Reply #6 on: July 01, 2017, 11:44:17 PM »
New switch assemblies are $140 plus shipping at EME. Somebody out in the Web might be fabricating only the parts you need, if only you can find them. Used ones will surface but you need to make a list of bike salvage outfits, visit their websites regularly and pounce when you find one.
« Reply #7 on: July 01, 2017, 11:51:10 PM »
Here is a site with photos. Use Google Translate to translate the text in you can't read German.
http://technik.flyingbrick.de/images/f/f9/61_lenker_rechts.pdf
