So when I pulled the clutch pack it pretty much exploded onto the floor. Clumsy me. No chance of knowing its original balance configuration.
After cleaning, two parts have obvious markings, however the pressure plate has a marking on each side and I can't decide which is the one to use.
The more obvious pressure plate marking is white paint over a drilled indentation, while the mark on the other side is a faint yellow on the flexible band.
If I were to choose the painted white markings on each pressure piece, those marking would be almost 180 degrees apart when assembled.
If you have experience with these clutches please let me know the kind of marks you have seen and used.
