MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: Filmcamera on November 14, 2016, 08:55:04 AM
Title: WTB ABS 1 mounting brackets
Post by: Filmcamera on November 14, 2016, 08:55:04 AM
Hi
I am looking to reinstall the ABS that the PO had removed.
To do that I am looking for the mounting brackets etc to mount the modulators.
If anyone who has removed their ABS has these bits for sale that would be great.
The hoses would be a bonus if they are in good shape.
So basically looking at the attached diagram parts all of the parts on their except the actual modulator and the ABS sticker.
Title: Re: WTB ABS 1 mounting brackets
Post by: Laitch on November 14, 2016, 09:47:07 AM
If you ride steep gravel roads, ABS might be problematic. Read the text on YouTube accompanying the following video.
https://www.youtube.com/watch?v=8JhenlQlWuA
Post by: K1300S on November 14, 2016, 11:50:24 AM
good call putting the ABS back in.
don't (ever) use used hoses.  buy new braided or stock ones.
Post by: Filmcamera on November 14, 2016, 12:04:40 PM
You are right, I was looking at a set of braided ones - at $240 not cheap but so be it.  I just want to make sure I can get the modulators mounted properly first.
Also the reason the PO took off the ABS was that the brain broke - I purchased a used one from a fellow motobricker. but just noticed the broken one calls itself AB02.5 whereas the replacement I brought is AB01.5 - anyone know if the two are compatible?
BTW I try very hard to avoid steep gravel with out without ABS!
Post by: The Mighty Gryphon on November 14, 2016, 12:39:24 PM
I have most of the parts from my '92 K100RS ABS which was working when I removed it.  Brain, bracket, modulators, hard lines.  The harness is still on the bike, but I might be able to remove it if you need it.
Make me an offer.
Post by: Filmcamera on November 14, 2016, 01:32:05 PM
The Mighty Gryphon I sent you a PM.
