TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: k on November 04, 2016, 12:23:48 AM
Title: What's a Proper Kickstand Lean Angle for the K100?
Post by: k on November 04, 2016, 12:23:48 AM
Mine feels like it drops way over. Is this normal? I had an RT previously, and I don't recall that one leaning quite as far.
:mm
Title: Re: What's a Proper Kickstand Lean Angle for the K100?
Post by: TX brick on November 04, 2016, 04:48:52 PM
My 91 75RT leaned WAY over also and when replacing the pivot bushing didn't help much, I made a pad for the foot.  I used a one inch thick piece of plastic cut to shape and drilled two holes to bolt it on.
Post by: Chaos on November 04, 2016, 06:10:03 PM
they all do that.   check for loose pivot and or bent side stand.
Post by: Inge K. on November 04, 2016, 08:45:10 PM
or bent side stand.
Would like to add that they're slightly bent allready from factory.
Post by: The Dude on November 04, 2016, 09:43:12 PM
Standard tire profile and suspension?
Post by: k on November 04, 2016, 09:45:01 PM
Yep. No deviations.
Post by: The Mighty Gryphon on November 05, 2016, 09:43:51 AM
I suspect that the radical lean these bikes have when they're on the side stand is intentional to lower the seat height so as to allow mere mortals to be able to swing a leg over it.
