TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: DavidATL on October 15, 2016, 09:57:59 AM
The bike is a K75RT 3/92 build date. I've owned it a year.
Not knowing it's history, I thought I'd change the fuel pump damper before things got bad. I ordered what I thought would be the right damper and screen but upon removal, things are different than I expected. I'd like those with experience to comment on the situation and advise on next steps.
See the attached pic. It appears that the bike has a VDO pump with a strainer sock. Apparently the parts I purchased are for a Bosch pump with a strainer that caps over pump body. I don't think I can use this on my pump.
1) it appears that the rubber damper and plastic click-in-place mount are the same for both pump styles. Confirm?
2) the rubber damper from the bike appears to be in great shape and the fuel filter mfg date is 3/07. My guess is that the rubber and filter were changed around 07, and I am thinking I don't really need to change this.
3) There is a small tear in one end of the strainer sock so I need a replacement. This looks to be the right one:
http://www.beemerboneyard.com/16141341233n.html
confirm?
Thanks in advance for your help...
update - the new click mount and rubber damper are not for this pump. They are for a pump with a larger body. I suppose the Bosch is larger?
52 mm......Your is 43 mm......the screen in the link is the correct one for you.
Is the 43mm VDO pump the OEM part for this build month/ year 03/92? Or do it appear that it was retrofitted?
My 5/92 K75S has a 52mm pump. See http://www.euromotoelectrics.com/ for an adaptor sleeve.
Thanks Martin. That site is well documented. Had I seen it before, I would probably have the right parts already!!! :-)
