TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: TNastsyDwnTwn on September 09, 2016, 06:42:47 PM
I am changing my k bike into a scrambler and I have ran into a problem with the handlebar. For some reason the throttle trust won't slide onto it. I bought a 7/8 bar. Any suggestions will be appreciated.
Despite what advertisements may seem to imply, ⅞" is greater than 22 millimeters—the dimension of BMW K-bike handlebars. Many people just sand down the ⅞ handlebar until the BMW controls will slide onto it. Your challenge is not uncommon. What you mean by throttle trust I'll figure out after I get some sleep.
I meant throttle twist. Sorry. I guess that's what I will have to do tomorrow. Thank you.
Thanks. I'll stay awake a little longer then.
ok thank you. What is the procedure to lubricate the the twist handle so it will return to its previous position.
You'll find instructions on the procedure in a pdf in this post right here (http://www.motobrick.com/index.php/topic,1797.msg8852.html#msg8852). I'll add that you must be certain that the flange on the throttle grip isn't making contact with the throttle/master cylinder assembly because friction from that will slow the return, too.
You'll find instructions on this and other procedures in the Technical Library Card Catalog (Index) (http://www.motobrick.com/index.php/topic,1797.msg8852.html#msg8852).
Thank you so much. I appreciate it. :2thumbup:
Resist the temptation to hammer it :nono on, sand it down until it slides on.
I came very close but I resisted the urge! So what exactly would be best to sand the bars down with?
You're going need an experienced handlebar sander for that answer. I'm just an observer.
Emery strip on a roll, keep rotating it so you get it even, you could also use a file. Wrap a few of layers of tape to mark the length you require, this should stop you from marring the rest.
Ok just making sure by hand would be the suggested way.
So TNasty, you asked in my thread what I ended up doing:
I attacked the problem from both directions, I sanded the paint off the grip portions of my new 7/8" bars and I filed the internal diameter of the bmw controls. It doesn't take much, but it is extremely tedious. Took probably an hour and two beers. Use a rat tail file, about 3/8" round.
Ok thank you. I used a dremel tool on mine. Thank you.
