TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Steenbeen on July 29, 2016, 11:20:09 AM
I just got my bike working again. However, when I fully twist the throttle, it seems like I'm only twisting it halfway. While driving it's revving slower and slower the higher the revs get. How can I exclude that the previous owner tinkered with the throttle bodies? The little spring on the left side doesn't seem te compress, as opposed to the right side. I've added photos of the bodies at full throttle. Is this normal? I've never ridden a k100 before, but if I look at videos on youtube, my acceleration seems really slow compared to the bikes on youtube.
Also, what is exactly the function of the TPS? What would happen to a normal running bike when the plug of the TPS is pulled?
Thanks.
Edit: added photos, site acted wierd.
Is the little vacuum tube wrapped with a metal spring coming off the rearmost throttle body intact, or is it cracked and leaking. The visible side is easy to check, but the rear part to which it runs is difficult. A leak will cause very high fuel rail pressure and engine will not make good power above 4k rpm...
Check for air filter blockage, I believe you guys can have nesting problems with critters and or fuel filter blockage.
Thanks for the suggestions.
The vacuum tube seems fine at a first glance. I think the previous owner said he cleaned the air filter and replaced the fuel filter, I'll ask.
What would happen if the fuel pressure is too high?
It's pretty strange. It will rev over 4000 rpm in lower gears, but very slowly. Not at all what I expect from a 66 kW bike. It's not really faster than my 11 kW Honda CBR125R. When on the highway it tops out at about that many revs.
I checked the TPS. It didn't click at all first, now I adjusted it so it clicks when the throttle is slightly turned. However, I tried driving without the plug attached to the TPS, and it didn't seem to make a difference... Should it make a notable difference? If so, maybe the switches inside are corroded.
unless my eyes are deceiving me, something ain't right with your tb's. when you open the throttle, all the tb's should open together, in synch. just from your pictures, it does not look like that is happening. a video of the tb's while you twist the throttle would be helpful.
i also see severely cracked caps on your vacuum ports. that tells me that all the rest of the rubber in the intake system is probably cracked too and needs replacing. you could have some massive vacuum leaks.
Link: https://www.youtube.com/watch?v=_NpRS6qa06M&feature=youtu.be
Let me know if it's not clear enough. Is the speed of which the revs are increasing normal?
I'm not sure about vacuum leaks.. Wouldn't that cause wierd irregular behaviour? It drives fine, just kind of slow.
Have the throttle mechanism at the handlebar been dismantled?
If so, have the mechanism been properly set afterwards?
The toothed wheel attached to the chain is marked with a line, this line
should correspond with a line on the toothed part on the throttle handle.
. . . something ain't right with your tb's. when you open the throttle, all the tb's should open together, in synch.
. . . all the rest of the rubber in the intake system is probably cracked too and needs replacing. you could have some massive vacuum leaks.
+1
+1
It wasn't. There was a lot of grease in there so I didn't noticed the line. I just set it to the first position it 'clicked' into. Not sure if it did make a difference, I can twist the throttle about 90 degrees, which seems kind of small compared to my other bike and other bikes in particular.
I can't learn from your response to Inge if you have properly aligned the throttle mechanism yet, Steenbeen. Have you?
What the "my other bike" you mentioned?
Sorry, I see now that it wasn't really clear. It's now properly aligned. It was set a tooth too 'early' at first.
My other bike is a Honda CBR125R. My fathers bike, a V-strom, also has a larger maximum throttle angle. The angle of my K seems kind off small, but as this is my first K, I'm not sure if it's normal. If not, then that would be the problem.
My K75 throttle rotates 90º and that's as far as I'd want it to rotate.
Good to know. That shouldn't be the problem then. Would it act like it does if the throttle bodies weren't correctly synced? How do I know if they are synced correctly?
Before you go any further replace the rubber caps.
if that is as far as they open, you have a throttle problem. should open a lot more than than.
as to vacuum leaks. if there is a big leak, then the mixture goes lean and power goes away....which is the symptom you are having.
I can't push them any further by hand than you can see on the video. By them I mean the mid and right bodies. I can however push the left one a bit more up, compressing the little spring. What could 'block' them from opening any further? I think the previous owner may have mounted it incorrectly.
As for the air leaks, I'll be sure to check the rubbers and replace the caps.
Try to remove the TPS and see if that makes any difference to the throttle opening.
I was on vacation, so here's an update. I did a dyno run, since I had to classify it as <35 kW for my license, and I figured I should do a run before I fix the problem. Turns out, maybe my brick is from 1886 instead of 1986, because it has 18 hp, and should top out at 120 km/h. Graph is attached. I'm going to replace the caps on the bodies, but I'm not sure that would cause a problem like this.
I'm betting on that the throttle isn't able to fully open, so after replacing the caps I'm going to take a look at the inside of the bodies.
Turns out, maybe my brick is from 1886 instead of 1986, because it has 18 hp . . .
:laughing-on-ground:
Did you check the throttle position sensor as recommended by Inge?
Yeah, I just checked the TPS. Didn't seem to make a difference. However, I just found out I need a new throttle first... The teeth on the throttle bar are flattened, and it would 'skip' through the teeth when force was applied. The damage was hidden under a lot of grease.
Update:
I finally took some time again for this problem after some other repairs. I uploaded a video on youtube which shows the inside of the throttle bodies when twisting the throttle to 'full' (sorry for vertical video syndrome). Seems to be a lot less than they should. What could be blocking them? I can't push them farther than this by hand.
https://youtu.be/B7vQtxrqahw
there is your problem as we suspected. those butterflies should open to be fully vertical at wide open throttle.
Definitely not getting full throttle, now you need to check why. When you move them by hand try to see if there is anything stopping the movement. How much movement do you now have at the throttle, is it 90o.
I think you have a problem with the linkage set up. I went back to your first pictures and noticed the idle adjustment screw is well off its stop. try to take more pictures of the throttle body linkages with the throttle fully closed and the throttle fully open. In order to get good pictures you might have to disconnect the wiring to the injectors.
Thanks Martin and mlytle. The photos I posted are both on full throttle. I'm not home until friday. Can you make something out of the first video I posted, Martin?
I didn't inspect the bodies thorougly yet, but there didn't seem to be anything that blocks it on the outside. The throttle movement looks like close to 90 degrees, but still a lot less compared to another K100 I checked yesterday. Just to be clear, I can't push them further by hand than I can by twisting the throttle.
How could the linkage be set up wrong? I'm pretty sure the previous owner disconnected the bodies before he sold it to me so that could very well be the problem, I guess.
You definitely don't have full throttle, I measured 45mm between the end of the idle screw and the stop. My screw at full throttle is level with the top band clamp on the throttle body. Do you have another bike that you can compare it to? It is possible that it has been assembled incorrectly I can't tell from the pictures. Is there a foreign body jammed in there .Possibly another member on this site might have a set of throttle bodies that they can photograph for you to compare.
Hope this helps. Type in BMW K100 throttle body images on the net lots of pictures.
It appears that Somebody took your throttle bodies apart and mounted the bellcrank (circled in red below) for the cable 90 degrees off. i've not ever taken these apart but that's what it looks like to me. As a result the back edge of the bellcrank is hitting the back rail and you can't open any further by cable or by hand.
It's correct mounted, if not the stop screw would also be out of position......it isn't.
Remove the TPS completely and retry.
That was allready mentioned back in reply #16...........didn't make any difference he said.
You haven't told us what was done about this condition?
Marked solved!
First, thanks a lot for the responses and the time that went in them.
Sometimes the vaguest problems have the easiest solutions. The most right bottom hose clamp was turned in such a way it blocked the butterfly. The manual says that the middle two bottom clamps should be turned about 35 degrees to avoid blocking the butterfly. I guess the previous owner misread and turned all clamps 35 degrees. I couldn't see it until I was ready to disassemble the butterfly. It cost me some time to find out, but I hope someone else can avoid this by reading this topic.
The culprit:
:2thumbup: :clap: Observation patience and persistence.
Good job! Way to persevere now what'll she do? 120 mph, 130?? We need to know :yes
Thanks for the followup, Steenbeen!
yeah!
@filmcamera
I don't know yet, guess I'll have to go to the autobahn to test it out!
I had my first drive just now, and my oh my what an absolute monster (the first 1000cc bike I've driven). Really happy with the bike now!
