TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Rokah on October 14, 2019, 06:46:11 AM
Title: K75 neglected for two years
Post by: Rokah on October 14, 2019, 06:46:11 AM
Hi, I've been gifted with a '90 K75 that doesn't start. I don't know much about it, except that one day the bike stopped and the owner never bothered to fix it. It's been two years since that...
General state: Bad. broken foot rest plates (PNs 46711457234 & 46711454485).  Bent back brake foot lever. Rusted forks. Rusted gearbox oil plug (07119919143). Broken headlight glass. Bent front brake lever & handlebar. Cracked vacuum plugs (13547694924)
Rust in the battery strap (and installed incorrectly): PN 61211459044
Sulfate in battery holder and rusted Vibration dampers (PN61211233028 )
Petrol tank installed incorrectly, missing (PN 16112309163) vibration dampers and missing retention clips PN07129934336
Battery: around 5. (The clock is still running though)
Brakes. Front brake works, back brake doesn't. The reservoir is empty
Coolant level: low
Oil level: On the lowside but still has some.
Spark plugs: horrible condition, they had screw terminals and I believe this bike had a solid terminals (Bosch X5DC or NGK D7EA)
Fuses: all OK
The goal is to make it start before doing anything else; I have the feeling the last guy who worked on this bike didn't have a clue on what he was doing.
Title: Re: K75 neglected for two years
Post by: Rokah on October 14, 2019, 06:46:31 AM
I've purchased a new battery (EXIDE GEL 12V 19AH GEL12-19) and new spark plugs. they have been tested by connecting them to the HV leads and grounding them to the chassis. they all make a blue spark. Injectors have been removed from the throttle bodies and they all spit petrol. The bike still won't start
However, it now cranks with force and Injectors spit fuel
Bottom line: electrical systems seems in top condition and grounding of the battery looks ok.
I think the next step I will take is to remove all fuel in the fuel lines/injector rail.
What do you think I should test next? Fuel pressure or compression? Should I go directly for the compression test?
Post by: daveson on October 14, 2019, 08:08:43 AM
Fix all these faults you have found, especially the vacuum leaks. Put a bit of oil in the cylinders to improve sealing. Give it a service.
Post by: Rokah on October 14, 2019, 09:00:57 AM
Will do!
Is this a regular cranking noise?
https://photos.app.goo.gl/ikKFshWSoBtZCKnE7
 (https://photos.app.goo.gl/ikKFshWSoBtZCKnE7)
Post by: Laitch on October 14, 2019, 09:25:41 AM
Is this a regular cranking noise? Should I go directly for the compression test?
The sound it makes during starting is not unusual. Limit the duration to five seconds. Disconnect the battery or connect it to a tender when you aren't working on the moto.
A compression test is uncomplicated. Do it. Check each cylinder with the throttle wide open. After the first reading of a cylinder, repeat after spraying some oil into the cylinder to see if that raises its value significantly.
Top up the coolant. Change the oil and filter. The fuel tank should be cleaned. The fuel filter should be replaced. The tank interior fuel lines should be replaced with new 30R10 lines. The valve clearances should be checked and adjusted if necessary. The new spark plugs' gaps should have been checked before installation. The air intake and filter should be checked for restrictions; the muffler outlet should be checked for restriction. The z-tube crankcase-to-airbox connection should be checked that it isn't severed.
After doing all that, try starting it.
Post by: K1300S on October 14, 2019, 11:30:38 AM
exactly what he said....perfect pre-start checklist.
Post by: Soggz on October 14, 2019, 12:17:20 PM
Good Luck. Mine was neglected since 2008.Getting there though.
Post by: Rokah on October 18, 2019, 12:46:11 PM
Hi everyone! I followed some of Laitch's advice but i have bad news
Spark Plugs were set somewhere around 0,6&0,65
These are the compression tests I did:
TestCylinder 1    Cylinder 2    Cylinder 3
Without adding oil75 PSI0 PSI150 PSI
Adding 5cc of oil to each cyl100 PSI0 PSI160 PSI
As you can see, cylinder #2 is dead, and cylinder #1 is low on compression.
regarding the valves I measured the following clearances:
Inlet0.15-0.200.15-0.200.15-0.20
Exhaust     0.20-0.250.25-0.300.15-0.20
As far as I understand I have to change the shims on the exhausts valves of cylinders #1 and #3
I am thinking I will have to dismantle the head of the engine and check the condition of the head gasket, hopefully my its not the piston rings.
What would you do?
Post by: Laitch on October 18, 2019, 01:10:27 PM
What would you do?
I don't understand your measurement results. There should be one value for each valve, not a spread of values. Because these figures don't make sense, I wonder if your compression technique might be flawed also
Explain exactly how you tested the compression and exactly what type of tool you used to perform the test.
Post by: Rokah on October 18, 2019, 01:30:47 PM
Sorry I didn't explain. My gauges go in 0.05mm increments, the first value I was able to fit and the second I wasn't, therefore I know the gap must rely somewhere between the two values.
Compression I measured using this https://www.amazon.es/gp/product/B074CT56FF/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 (https://www.amazon.es/gp/product/B074CT56FF/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1). Removed all the sparkplugs, and then fitted the gauged and cranked the engine with the throttle open until the gauge reached a maximum. Then, repeated for the rest of the cylinders
Post by: Laitch on October 18, 2019, 01:57:09 PM
OK. All the intake valves are good. #1 and #3 exhaust valves need adjustment.
You need to do a leak-down test if you don't have a camera like the one in the attached video that can look around via the spark plug hole. These cameras are surprisingly inexpensive. They are called borescopes. #2 and #1 might have severely damaged valves and/or valve
seats.
https://www.youtube.com/watch?v=Q6pjtceXogc
Post by: Rokah on October 18, 2019, 02:21:01 PM
Do you think its worth testing? I mean, i know there must be something wrong with the valves. I might as well just disassemble  the engine head and take a look with my own eyes and fix it while its open. Don't you think?
Thanks for the help!
Post by: The Mighty Gryphon on October 18, 2019, 02:26:36 PM
I'm guessing that you have some burnt exhaust valves.
If it were mine, I'd pull the head and take a good look.  If there's damage, I'd be looking for a used head at ebay and a new head gasket.
Post by: Laitch on October 18, 2019, 02:51:28 PM
I agree. The odd part is valve clearance is good on the worst cylinder. There could be broken valve springs in the mix.
Take your time. Use plenty of heat, penetrant and impact on the head bolts before attempting to loosen them.
Post by: Rokah on October 18, 2019, 03:40:27 PM
yuuuuuup that I find weird as well! I'll get back with updates!
Post by: The Mighty Gryphon on October 18, 2019, 04:06:54 PM
Make very sure you have a new tight fitting Torx wrench of the proper size to remove the head bolts. There are two types of Torx wrench, regular and heavy.  Later model bikes use the heavy.   The head bolts have a lot of torque on them, and the heads are easy to strip out.
You don't need to know how I know this.
Post by: Rokah on October 30, 2019, 05:33:35 AM
I doged that bullet!
It looks like I've found the reason for the missing compresion on cyl#2
(http://35.202.179.92/wp-content/uploads/2019/10/IMG_20191028_191839.jpg)
should I worry on how bad the cylinders look?
(http://35.202.179.92/wp-content/uploads/2019/10/20191028_191955.jpg)
To replace the valves, should I replace all of them, or can I just replace the broken one/ones?
Post by: Laitch on October 30, 2019, 09:00:57 AM
 Cylinder #1 compression is poor; the reason should be sought.
Post by: johnny on October 30, 2019, 10:00:05 AM
you sparker orientation looks like a you gotts a low and a high simotaniously on the weather map...
that caint be good...
* 20191030_085315.jpg (32.12 kB . 324x576 - viewed 857 times)
Post by: Laitch on October 30, 2019, 11:03:57 AM
omg :-)
Post by: Laitch on October 30, 2019, 11:43:42 AM
The difference in compression values after adding oil is probably symptomatic of stuck piston rings, which happens after neglect and usually ends after the engine is run in again.
Post by: Rokah on October 30, 2019, 12:20:31 PM
omg :-)
Calm down gents, those spark plugs are loose! I put them in just to take the picture.
I'm going to buy a new valve and get a quotation for a head and valve resurface
Any more suggestions?!
Post by: Chaos on October 30, 2019, 12:53:49 PM
Does anyone index spark plugs anymore?  Does it even matter?
Post by: johnny on October 30, 2019, 01:55:59 PM
greetings grandpa...
it matters... thats why i use e3 exclusively...
that and 10 moar horsepower with diamondfior technology... (https://e3sparkplugs.com/motorcycle-spark-plugs/)
thats 2.5hp a hole... you would getts 7.5hp combined on your minibrick.. itsa game changer for sure...
* Screenshot_20191030-125443.jpg (30.66 kB . 403x576 - viewed 881 times)
Post by: Chaos on October 30, 2019, 04:14:35 PM
do they make them for chippers?  mine bogs down with fat people
Post by: Laitch on October 30, 2019, 06:04:36 PM
Get the head analyzed by somebody who is experienced. Cylinder #1 is compromised. You're likely to need more parts than just one valve.
I bought cubic zirconia-tipped plugs from Alibaba and saved 20%.
Post by: Martin on October 30, 2019, 06:34:00 PM
Sometimes it is cheaper to get a good 2nd hand head, engine or whole bike than reco a cylinder head.
Post by: alexg on October 30, 2019, 06:54:17 PM
 I would not do anything until after you clean the thing and are sure that there is not a crack in the valve seat where the it burned. Sometimes the seat gets damaged as well, and then you are for an expensive repair.
Also, with high compression engines, I am not fond of resurfacing heads unless there is no way to reinstall successfully. Why resurface the head? Is it warped or corroded? A good bead cleaning should be enough. Take all the valves, not just the burned one.
Post by: Rokah on November 11, 2019, 03:29:35 AM
Managed to borrow for a few minutes a BMW Valve Removal tool
After cleaning, this is the state of my exhaust valves and valve seats. What are your opinions? Is there a way I could avoid the BMW tax of around 150€ for the cracked exhaust valve?
I am also worried about the valve guides being too loose. I removed the Oil seal and when open the valve can wiggle around 0.5mm  :S
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191109_132252-e1573460604313.jpg)
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191109_131628.jpg)
Post by: Laitch on November 11, 2019, 07:08:27 AM
I can't get much from those two photos. Many profiles of each part should be taken and identified by cylinder and function. You probably should consult an engine machinist for an accurate assessment. Try consulting one that isn't a BMW technician.
Download the K75 K100 2V manual from this site. Go to its Engine section index. Go to the Specification section within that index. In that section are listed the allowed clearances of parts throughout the engine. If your description of both the part and its clearance is accurate, your measurement seems to indicate excessive wear.
Watch this video for measurement technique. It isn't child's play and needs accurate measurement tools and technique. Let us know your results.
https://www.youtube.com/watch?time_continue=91&v=LIL1lV_xtHI&feature=emb_title (https://www.youtube.com/watch?time_continue=91&v=LIL1lV_xtHI&feature=emb_title)
Post by: alexg on November 11, 2019, 07:43:52 PM
The valve stem is worn out probably. Try measuring with a micrometer at place where the valve guide rides and near the end of the stem, where there is no wear. You can measure the diameter of the valve guides with a series of # drills. I agree with Laitch, the play is excessive.
Changing valve guides is repair shop territory: warming up the head in a control temperature oven (not over your kitchen range), driving the old guide out without banging anything else, driving the new guide all the way to the spec height w/o misalignment, and then, machining the seat to have it concentric with the new guide, and shaving it to spec width. Not impossible, but requires practice, and a lot of special tools.
I agree that the price of an exhaust valve is exorbitant, but for an exhaust ventile, might not be  :(
Curious: how many miles in this bike; for the wear of the valve seal surface, a lot.
Post by: The Mighty Gryphon on November 11, 2019, 09:23:43 PM
By removing the head and getting the valves out, you have done the worst part of a valve job.  Take the head and the valves to an automotive machine shop for a quote rebuild the head.
Another option would be to look for a used head with good valves.  You should be able to get the head squared away for the price of a couple good tires.
Post by: riots100 on November 11, 2019, 10:58:04 PM
Any shop that rebuilds cylinder should be able to take care of yours.  I had a local machine shop rebuild mine from my K75 and it went smooth as silk.  The shop I went to also offered cleaning bath as well.  The only parts that were replaced were the valve guides.
Post by: Rokah on November 12, 2019, 02:14:12 AM
Thanks for all the answers, I had the head in the trunk of my car waiting to be taken to a friend of mine that has access to a CMM (coordinate measure machine) but I took it to the machinist directly as he was not going to trust my measurements anyway.... As soon as he saw the valve play he mentioned changing the guides. So I asked him to give me a quote on replacing all the valve guides and doing the seats. I've seen at realoem.com that the valves have a +Core note beside them (plus core charge (possibility of a return of the old part)) I will try to contact the mothership to see if they offer discounts for bringing the old in.
97k miles according to the dash (157k KM)
It has really been a breeze up to now! Both with a few workshops in Madrid an with you guys. Lets see how well the machine shop quotation treats me.
looks like we are having parallel stories.
Post by: Rokah on November 26, 2019, 03:48:05 PM
While the head is in the machine shop, i've been inspecting a few other parts.
What do you think about these parts. Should they be replaced?
Chain tensioner (plastic part)
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191126_200956.jpg)
Chain tensioner (metal part) Is that dent normal? should I worry?
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191126_200931.jpg)
I believe this pump shaft is OK
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191126_200807.jpg)
State of rubber screw gaskets
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191126_201035.jpg)
pump shaft seal
(http://35.202.179.92/wp-content/uploads/2019/11/IMG_20191126_200859.jpg)
Post by: Rokah on December 03, 2019, 02:02:47 PM
I've bought a set of pistons+rings from a guy that used to run a BMW dealership. Quick question, do the big end connecting rod bolts need to be replaced once the are loosened? I am aware that they are torqued on an angle basis but they seem to be a bit hard to remove from the conrod.
Post by: Laitch on December 03, 2019, 02:50:33 PM
. . . do the big end connecting rod bolts need to be replaced once the are loosened?.
The bolts don't need to be loosened. Are you using a manual?
Post by: Rokah on December 03, 2019, 03:15:11 PM
Then how do you remove the pistons?!
I'm on step 5 of this page: http://www.bmw-k100rt-page.eu/manual/Engine/examinationEngine_22.htm
Post by: Laitch on December 03, 2019, 04:41:27 PM
You remove the nuts on the ends of the bolts. The bolts stay in the rods, the piston is pushed out of the cylinder by pushing against the inside of the piston with a hardwood dowel or any suitable object fit for the purpose that won't damage metal parts. This is explained in Part 10, steps 6 and 7 and illustrated by a photo show the bolt in place.
The first rule of performing any procedure is read the entire procedure first—maybe a couple of times—then think about it, answer questions you might have about it, then start it.
Post by: riots100 on December 04, 2019, 11:35:26 PM
I did not replace the connecting rod bolts or nuts when I replaced my bent connecting rod.  Just torqued it to spec.  All has been good since.
Post by: Rokah on January 01, 2020, 05:43:42 PM
Engine done! It started on the first try! Thanks for the help!
Post by: The Mighty Gryphon on January 01, 2020, 05:52:38 PM
Can you tell us what was done and parts that were replaced?
Post by: Rokah on January 02, 2020, 12:40:53 PM
of course!
Piston + Rings (I got a deal)
Big end bearing shells
Big end bolts
Full head(All 6 valves+guides+guide reaming+ seat recut + surface)
New head gasket
new original pump seals
and then the basic maintenance pack, filters(air + fuel + oil)
All o-rings and seals were also changed including the copper ones.
Post by: The Mighty Gryphon on January 02, 2020, 01:06:59 PM
Nice!  It sounds like you're riding on a new engine now!
