TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: boostd4 on July 24, 2017, 10:05:40 AM
Title: Any tips for strap-ons installation?
Post by: boostd4 on July 24, 2017, 10:05:40 AM
Looking to install a set of strap-ons bars.  Not trying to lower the front end, so would like to mount them just below the top clamp for the forks.[/size]I've been working on cars for 20 years but this is the first motorcycle I've customized (had bikes before but outside of slip-on mufflers and stuff, haven't had forks apart, etc).The front brake line appears to go through the middle hole in the triple clamp.  I don't see away around having to disconnect it and bleed the brakes to do this.  Are there any tips/tricks for this kind of replacement?I know there are some hinged strap-ons's out there that may not require this.  I haven't settled on something like that yet because of price, but am open.Thanks![/color]
Title: Re: Any tips for strap-ons installation?
Post by: The Mighty Gryphon on July 24, 2017, 10:26:29 AM
Are you talking about installing clip ons?  Am I missing something here?   Just remove the front wheel, and the calipers from the lower fork tubes.  Loosen the clamps and slide the tubes down, put the bars on and slide the tubes up.
Post by: BrickMW on July 24, 2017, 11:55:57 AM
I don't think he wants to bleed his brakes... :dunno2:
...but this is the first motorcycle I've customized
The front brake line appears to go through the middle hole in the triple clamp.  I don't see away around having to disconnect it and bleed the brakes to do this. I know there are some hinged strap-ons's out there
Yes, you will need 2pc / hinged clip on's to avoid disconnecting the brake line that runs through the head stock.
Removing the calipers would allow the forks to slide without disconnecting the brake line. Thank you Laitch for making me think.. :2thumbup:
Although, that task really shouldn't be that intimidating.. hardest part is keeping the DOT4 off your paint..
Post by: Laitch on July 24, 2017, 01:59:35 PM
Removal of the brake pipe should be unnecessary. Follow Gryph's suggestion above and the one that you were already given here. (http://www.k100-forum.com/t12728-triple-clamp-removal-for-strap-ons#151011)
Post by: jaxon on July 24, 2017, 02:42:50 PM
strap-on spelled backwards is no-parts...
 That makes sense on multiple levels.
Post by: boostd4 on July 24, 2017, 04:36:00 PM
Thanks for that!  I cross posted these threads simultaneously (I'm not so impatient that I couldn't wait for a response on one forum, just thought I'd reach the most minds this way).
The caliper trick is a good idea, thanks.  I may end up getting hinged strap-ons anyway.
FWIW, this forum corrects "clipp-ons" to "strap-ons" and not during the preview - you can't tell it did it until your message is already posted.  Kinda stinks for searching. (I had to add the extra p's to even get it to post at all).
Post by: johnny on July 24, 2017, 04:48:53 PM
i hear you can score strap-ons at any cook county forest preserve... i hear you can getts hands-on training as how to mount them there too...
Post by: herseyb on July 24, 2017, 05:02:25 PM
Not ANY cook county forest preserve, that's Fox News anti-Chicago propaganda.
You gots to go to this one to get yer oil checked:   https://goo.gl/maps/MNy4uZyFEPS2
