Author Topic: New BMW K purchase Newark UK (not New Jersey)  (Read 22201 times)
Re: New BMW K purchase Newark UK (not New Jersey)
« Reply #25 on: May 01, 2017, 03:24:10 PM »
BMW installed a nifty feature that allows you to test whether it is running rich or lean. With the bike idling at 1000 rpm press the green start button, if the mixture is right the revs will remain the same or rise slightly.  If the revs rise a lot or drop the mixture is out. This is a feature that BMW built into the bike and as long as it is idling at 1000rpm or above the starter will not engage. You can apparently also use this feature as a boost.  http://www.motobrick.com/index.php/topic,3690.msg22201.html#msg22201
Offline The Dude
« Reply #26 on: May 01, 2017, 04:20:18 PM »
"10% Boost!"
I'll use it next tricky situation. :riding:
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline @ndy
« Reply #27 on: May 09, 2017, 10:12:51 AM »
Hi Just want to thank everyone for their advice and encouragement and to give you all a bit of an update.
I am still very pleased with the bike it really is a nice ride. all the negative things people say about them are complete rubbish...
Top heavy, really? I find it very well balanced and easier to push around in my garage/driveway than my XJ600. yes if you are dumb enough to lean it over too much while you are pushing it around it can suddenly get "a bit heavy" but why would you do that...
It is hard work and heavy in town traffic... nothing could be further from the truth, I find the K75 a breeze in town and very stable and well mannered at slow speed maneuvers.
The gear change is clunky and agricultural.. bull sh*tt!!! I suppose it depends what you are used to but I find the clutch light and the gear change smooth and positive.
The K series are Characterles... I don't agree with this either... yes the bike is smooth, well mannered, well designed and I guess from the design quite maintenence free (by this I mean you shouldn't need to tinker with it every time you take it down to the shops). But the design is quirky and full of character, like owning a classic Citroen!!
All in all I love it to bits.
I did a major service over the weekend but still have a few jobs to do, this is what I have done:
changed the oil and filter,
Changed gearbox and final drive oil.
Cleaned and greased the drive shaft splines front and back.  (the front ones were perfect and still had grease, the back ones were dry and a bit        rusty showing signs of mild wear so I guess I caught them in time)
Air filter
Bled the breaks through with fresh fluid
Checked out the brake pads
cleaned and greased the twist grip mechanism
Checked for air leaks
Tappet/valve clearances...  well these were all just a little tight, one in particular exhaust cyl 1 (front pot) was almost non existent 8 thou too                                                       tight. I was able to surface grind the shims to the appropriate sizes so now all good.
balanced the throttle bodies
certainly improved how it runs.
I am now quite sure the noise I hear is nothing to worry about, bit of a rattle when Opening the throttle from idle, only when opened suddenly... seems to be a K series trait from what I have read... I don't think it is the Alternator drive or the final drive/balance shaft...
Still a bit of a misfire thing going on when warm and held at revs no load. 2500-3000 or so... but not evident under load, I don't know if this is normal or whether it could be some slight vale damage from the tight clearances,  nothing showed on the vacuum gauges but I guess I need to do a compression test.
I haven't changed the coolant yet but I thought I might just do a coolant/oil pump overhaul/seal change... is this a good idea rather than waiting until it goes. There is some oil from the clutch housing, just a little. I am guessing rear engine seal or gearbox input seal or both are weeping but I will wait until it gets bad or I have to split it for something else like clutch before doing it.
I found that one of my tragkorb brackets were broken, so I fashioned a piece of aluminium and fixed it to the plastic with some M4 screws, now my tragkorb doesn't wobble about... I also found corrosion under the rear brake pedal. the par you put your foot on is coming detached from the "stalk" the metal underneath resembles some kind of wafer! I haven't decided whether to simply replace it (they seem a little expensive) or weather to fabricate a new pedal to and fix it on....
anyway it is all making me smile! :-)
  • Newark on Trent UK
  • K75RT
Offline @ndy
« Reply #28 on: May 09, 2017, 10:48:32 AM »
Oh almost forgot, have a wobbly right hand front brake disc too! previous owner did tell me about it... it isn't really bad. I'm looking for a used disk but I'm also considering surface grinding it, I think I can get it true without it being under minimum prescribed thickness.
  • K75RT
« Reply #29 on: May 09, 2017, 10:55:53 AM »
. . . all the negative things people say about them are complete rubbish...
Lofty. Breathtakingly lofty!
As far as the coolant pump goes, I suggest that if it isn't broken, don't fix it. Instead, do a thorough coolant system/block flush then replace the coolant with long-life coolant and distilled water in the correct proportion for the climate in which the bike is too be ridden. Of course, you would know best.
Offline Doodaadog
« Reply #30 on: May 19, 2017, 03:57:10 PM »
Hey....I'm just down the road in Lincoln...(not Nebraska) just bought a
K1100 LT with the intention of making a restomod cafe racer of some sort....mine had been stood in a shed for 7 years....so still working on getting it running....bought mine on eBay as a non runner...good news is that the plate is worth just under what I paid....so low risk if it turns out to be a lemon...
If you want to compare notes.....or meet up for a beer/coffee let me know...Greg 01522 790717 or 07955 550861
  • Lincoln, England
  • K1100LT 92
Ducati Monster 1200s
Montesa 315R
BMW K1100 LT
