Author Topic: Re: Transmission leaking gear oil  (Read 3690 times)
Offline SJK
« on: February 02, 2017, 02:48:31 PM »
Hi Frankenduck, thax for this great informative post.
I however seem to have a leak in the rear transmission area you have not mentioned, its leaking from the seal around the spline(where the swing arm connects)  just above the clutch arm boot.
Do you by any chance know the part number for this?
after miss understanding your post I ordered part number 23121451151 , but its too small :(
  • Cape Town ,South Africa
  • K75 1989
Offline thecableguy
Re: Re: Transmission leaking gear oil
« Reply #1 on: February 02, 2017, 03:27:08 PM »
A quick look at Max BMWs parts fiche shows this for the trans output shaft:
23_1156 - 5 SPEED TRANSMISSION-OUTPUT SHAFT
You appear to want part number 18 on this drawing.
[/size][/color]
18
23 12 1 451 024 SHAFT SEAL - 25X40X7
0.02
$20.20
  • Madison, WI USA
  • 86 K100RT - Brünhild
...to make a long story short, use duct tape.
Offline SJK
« Reply #2 on: February 07, 2017, 12:02:53 PM »
Thank you very much Sir, that looks like the one I need and the sizes you give below is the same as the old one. will order today.
 :2thumbup:
  • K75 1989
Offline DannyBoy1798
« Reply #3 on: April 22, 2017, 05:20:35 AM »
Hi Guys, I have the same problem with an oil leak from the transmission output shaft where the driveshaft fits onto. I was wondering if this seal can be replaced easily without opening the transmission or if there are any special tools? I just scored an 88 K75C and it's a thing of beauty and real smooth to ride. Any assistance would be appreciated, thanks!
  • New Zealand
  • Suzuki Bandit 600, Yamaha XJ550, BMW K75C
Offline Filmcamera
« Reply #4 on: April 22, 2017, 07:16:42 AM »
Yes, the input shaft seal and the clutch rod push seal can both be replaced without opening the transmission.  I recently did both while doing a spline lube.  The input shaft seal is not an issue, the clutch push rod seal is a pain to get out but is eventually possible.
  • San Jose, Costa Rica
Poserbricker
