Author Topic: WTB ....... Bar Risers for a K75  (Read 9186 times)
Offline D.Bachtel
« on: April 11, 2017, 08:09:53 PM »
All this talk of handlebar positioning has me wanting to try a mild set of bar risers for my 1987 K75C.
Nothing severe but an inch up and back will allow me to stand on the pegs in a more upright posture.
Being nothing more than a trail rider for 40 some years I've grown used to standing on the balls of my feet when encountering tricky sections.
Love the bike and the speed it is offering, getting used to tucking in behind the cockpit, but sooner or later you end up taking a slow line.
Makes gravel seem like fun.
Don in Nipomo
  • Nipomo
  • BSA, Zundapp, Husqvarna, Greeves, Triumph...and a 1987 K75C
Offline D.Bachtel
Re: WTB ....... Bar Risers for a K75
« Reply #1 on: April 12, 2017, 11:57:33 AM »
Does anyone have bar risers that are in excess to their needs?
Don in Nipomo
  • Nipomo
Offline mw074
« Reply #2 on: April 19, 2017, 11:39:03 AM »
Don, I have these.
  • Michigan
Offline D.Bachtel
« Reply #3 on: April 19, 2017, 12:14:56 PM »
You have just about everything don't you? :clap:
Rise and pull back on those if you could, hoping to use my original brake line and cables.
Don in Nipomo
  • Nipomo
Offline D.Bachtel
« Reply #4 on: April 21, 2017, 07:21:01 PM »
I got these off  ebay  lastnight....  looking forward to a little pullback.
http://www.ebay.com/itm/122455747288?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks for the help.
Don in Nipomo
  • Nipomo
Offline D.Bachtel
Re: WTB ....... Bar Risers for a K75 hose recommendation
« Reply #5 on: April 27, 2017, 10:17:56 PM »
Got the risers mounted, now I need a longer master cylinder banjo line. The stock hose that came with the bike is 165mm.
Question... will the 249mm listed on Max be too long or just right? :dunno
Don in Nipomo
  • Nipomo
« Reply #6 on: April 28, 2017, 02:25:34 AM »
It's over 3'' longer, can you not measure from the of your old one. Once you have the measurement you can get one made up to the correct length. I recently had one made for a custom application by a local brake specialist. I got it very cheap from a friend of a friend deal but another specialist quoted $70.00 Au. Take the old hose with you to get all the angle orientations right..
« Reply #7 on: April 28, 2017, 05:56:48 AM »
If the rise and pullback in the eBay ad are accurate and because that hose was fabricated for use with an RT bar which has a 3" greater rise and a two inch greater width than the bar you're using and because you're the one taking the risk, I'm reckoning you have more than enough length to make the transition.
  :yes
Offline D.Bachtel
« Reply #8 on: April 29, 2017, 06:59:31 PM »
Hose on order from Max, not in their stock but still available. We'll see if it ends up being a drop shipment from somewhere closer.
10 days at most without the K75, so I gotta run the BSA or Zundapp on my late night early morning outandabouts on HWY1.
They all need to be exercised anyways...
I think the extra inch of rubber will just end up as a small offset flex loop and shouldn't be a problem, mechanically or visually.
Thanks for your help gentlemen!  :2thumbup:
Don in Nipomo
  • Nipomo
Offline Lastunder
« Reply #9 on: May 01, 2017, 07:35:52 PM »
In an effort to be Don's doppelgänger, I found the same risers and brakeline as him from A&S.  Not as sweet a deal as his EBay find, but still...
  • Alberta
  • '86 K75C
Offline Andy FitzGibbon
« Reply #10 on: May 02, 2017, 06:31:00 AM »
  • Montrose, WV
Offline D.Bachtel
« Reply #11 on: May 02, 2017, 10:37:23 AM »
A&S has a chart for hose fitment here:
https://www.ascycles.com/BMW-k100rs-parts-accessories/ProductID/387
Andy
Chart doesn't seem to jive with the hose I need and ordered but the shipping is FREE!
I'll keep them in mind next time before going to the Max.
Don in Nipomo
  • Nipomo
« Reply #12 on: May 02, 2017, 04:21:52 PM »
One of our local brake shops will make you a brake line while you wait. Choice of rubber or stainless lined.
Offline D.Bachtel
« Reply #13 on: May 02, 2017, 04:28:00 PM »
Warning...Your local brake shop may vary...
Thought about going to an AG Implement shop down in Santa Maria but went with the factory hose this time.
I will need to visit the hoseboys sooner or later to get the lift on my Cushman Turf Truckster to dump.
All I have to do now is wait.
Don in Nipomo
  • Nipomo
