Author Topic: Consistent and inconsistently bike shutting off  (Read 50868 times)
Re: Consistent and inconsistently bike shutting off
« Reply #75 on: June 03, 2017, 10:32:59 PM »
I know it's been a very long time since I visited this post, but I just wanted to submit the resolution: The inside of the FI Relay female center prong terminal was burnt out and making little/no connection.
Thanks for the followup! It helps show working solutions to others. Good riding!
Offline jakgieger
  • itinerant farmer
« Reply #76 on: June 04, 2017, 09:27:25 AM »
 :2thumbup: :2thumbup: GREAT!  Over the last month, I had been wondering, and fearing that you had given up in frustration.  I did feel a little guilty since I steered you towards the bike to begin with :yes .  Suffice it to say that I have worked on many mechanical problems over the years...all I can say is PATIENCE AND PERSISTENCE  usually carry the day!
  • Kansas USA
  • 1989 K100rs se
« Reply #77 on: June 04, 2017, 10:32:33 AM »
That is great news!  Thanks for letting us know how you corrected the problem.  I hope you enjoy the trip to Colorado.  Lots of really nice riding out there.
Lots of satisfaction in finding the cause of a problem and fixing it.  I hope you are enjoying the feeling of success.  :2thumbup:
Offline White Dog
« Reply #78 on: June 04, 2017, 11:02:39 AM »
Who would have thunk the blasted relay was bad?  I thought you swapped some relays around and they all worked.  Anyway, good job on getting it going.  With the trailer connector, the "destined to fail" 4 pin connector has been taken from the equation.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
« Reply #79 on: June 04, 2017, 11:53:43 AM »
Relays were mentioned half-way up the thread.
Offline KJM00
« Reply #80 on: June 04, 2017, 04:16:30 PM »
That's just the thing though alll relays were pristine and worked when I subbed them around, the only way I was able to tell the center prong insert was the problem was shining a light in the insert seeing a minor bit of soot and then completely dismantling the base, wasn't easy to fine it took a really long time, not much evidence to suggest
  • Lincoln, Nebraska
  • K75S 1993 blue and 2001 Kawasaki KL-250G SS
