Author Topic: Looks like a rebuild is in order...  (Read 19002 times)
Offline E30_Crazy
Re: Looks like a rebuild is in order...
« Reply #25 on: January 01, 2017, 11:56:29 AM »
I guess I'll have to apologize then, in case I wasted anyone's time with this thread. I just moved 7k miles, work close to 80 hours a week, blah blah, excuses excuses.
While some of my questions may have obvious answers, or easily attainable knowledge from manuals and catalogs, they were mostly a documentation of my thought process. I do appreciate all the quick, helpful replies.
  • Newport News, Virginia
  • '85 K100, '93 K1100RS
God created Crew Chiefs so Fighter Pilots could have heroes, too.
Offline E30_Crazy
« Reply #26 on: January 01, 2017, 12:04:10 PM »
Yup. Broken camshaft
The cam lobe looks pristine. I'd expect at least a little wearing to show, or some light pitting. This almost looks new to me. Goes to show the durability of these engines.
« Reply #27 on: January 01, 2017, 12:13:51 PM »
Is that the cam lobe or the broken shaft that shows the durability? :giggles
Thanks for the photo.
Offline E30_Crazy
« Reply #28 on: January 01, 2017, 12:21:11 PM »
Yeah, not so much the shaft, haha.
I'll be if I can dig it up, but there should be an entire build thread on here from the PO. Started out as a white RT held together by duct tape, if that rings any bells.
Offline E30_Crazy
« Reply #29 on: January 01, 2017, 12:36:31 PM »
Here's the original build thread, if it interests anyone. I guess it was close to 100k miles, if that is the original cluster.
http://www.motobrick.com/index.php/topic,7151.25.html
« Reply #30 on: January 01, 2017, 03:04:13 PM »
There still has to be a reason for the breakage. Beside the two I have already mentioned bearing failure or head warping, the only other unlikely possibility is metal fatigue. Where the breakage occurred can you see any sign of fatigue, pictures of the breakage end on may give a clue. An inmate who is into metallurgy may spot something. The son in law who was a workshop manager had a problem with a Leyland diesel bus engine breaking camshafts, but that came down to not replacing the bearings when replacing the camshaft. a bearing was nipping up when it reached temperature.
Offline E30_Crazy
« Reply #31 on: January 01, 2017, 04:57:52 PM »
I'll have to recheck everything. But I couldn't find any defects earlier. Maybe I'll start with a cheap(er) used cam if I don't find/correct any problems.
« Reply #32 on: January 01, 2017, 05:08:35 PM »
When checking use a straight edge and Plasti- Gauge. Replace the old camshaft and check with Plasti -Gauge on multiple points. If using a second hand camshaft again check with Plasti- Gauge.
« Reply #33 on: January 01, 2017, 07:27:48 PM »
Are there any options for upgraded/better power curve cams for the K100?
According to urban legend, the earliest (1984, '85) K's -- the Finest Year K's -- had "hot" cams and served up more horsepower than later years. Some believe this to be true, some scoff. Something to think about.
Offline E30_Crazy
« Reply #34 on: January 01, 2017, 07:40:09 PM »
That's what I've found too. Since mine's an '85, I'm now looking just to keep the correct cams in it. BSK has a set of reground performance cams, but they were a few hundred GBP, so nearing $500, even before international shipping.
Offline The Dude
« Reply #35 on: January 01, 2017, 07:46:37 PM »
Wow!
I hope#4 lobe was on the dwell part leaving the valve up and sealed.In which case you were lucky.Mind you,breaking a camshaft isn't.
 BMW had a voluntary 100 hp limit back then(no legend)so get a standard cam exchanged and concentrate on the new baby...and hope #4 's inlet valve isn't bent!
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #36 on: January 01, 2017, 08:17:54 PM »
I'd also be looking very carefully at the last bearing if this nipped, that is where the shaft would snap.
« Reply #37 on: January 01, 2017, 10:36:54 PM »
Is there any sign of excessive friction on the bearing surfaces of the last bearing?  Any blueing from excessive heat or visual scuffing?
Have you checked to see if the #4 intake valve moves freely.  I would think the cam lobe trying to open a stuck valve could put enough stress on the cam shaft to snap it.  Can you see a wear spot on the surface of the cam at thee spot where it will first contact the valve shim?  Are there any signs of wear on the valve shim?
It is possible the valve is not opening smoothly because the stem is bent.  If it is bent it's hard to say if the cam caused the bend or something else did before the shaft snapped.  In any event, I think you should check it.
