Author Topic: 1985 K100 RT That didn't run...does now with issues!  (Read 246560 times)
Re: 1985 K100 RT That didn't run...does now!
« Reply #250 on: May 27, 2018, 09:22:14 PM »
Ride on! :riding:
Offline Timbox
« Reply #251 on: May 27, 2018, 10:59:32 PM »
Congrags on putting her back together and having her run.  At this point do you really care what the fix was :)  I think all the hard work paid off and I am just glad you got her back on the rd.
  • Tomah, Wisconsin
  • 87 K100 RS
1987 K100RS current project :)
In shed: 07 Bandit 1250, 86 FJ1200, 85 Madura 1200 and KLR650
Offline Supershooter
« Reply #252 on: May 28, 2018, 10:12:53 PM »
At this point I have a leaky master cylinder and a headlight that only illuminates the parking light but not the large headlight. Should these issues be brought up in new threads or I this one?
Any ideas onthe headlight issue? From my research it seems like a load shed issue or high low switch issue, any things or first this then that advice.
I'm not sure if I want to tear into the dot 4 leak or not.
Supershooter
  • 85 K100 RT
« Reply #253 on: May 28, 2018, 10:55:04 PM »
Any ideas on the headlight issue? From my research it seems like a load shed issue or high low switch issue, any things or first this then that advice.
Keep the issues in this one. It's easier to keep track of what has been done.
Maybe your headlight bulb is burnt out. Believe it or not, that happens.
Offline Timbox
« Reply #254 on: May 29, 2018, 06:56:04 AM »
I would start with what ever area you feel is easiest.  One end (the head light) or the other (swx).  I think my swx was in need of some TLC and once I cleaned it, it felt like it should have in the first place.
  • Tomah, Wisconsin
  • 87 K100 RS
« Reply #255 on: June 06, 2018, 10:34:11 PM »
Since I'll be disassembling the head light, are there any recommendations for a better bulb/LED or such?
Supershooter
  • 85 K100 RT
« Reply #256 on: June 07, 2018, 06:02:24 AM »
If this were my bike, I'd install a $10 60/55W H4 to determine if the bulb is the problem. If that fixed it, I'd buy another $10 60/55 H4 as a spare and swap it in next season if necessary. There's always this to consider though. :giggles
« Reply #257 on: June 10, 2018, 02:05:30 PM »
When I test the headlight working at the plug what should my reading be and which wires at hot an ground?
Supershooter
  • 85 K100 RT
« Reply #258 on: June 10, 2018, 03:26:15 PM »
White = High beam
Yellow = Dip beam
Brown = ground
Best mod to do to your lighting system, better than any aftermarket bulb, is to install an Eastern Beaver relay kit or DIY the same thing.
Do you get high beam when you try the Flash button on the left hand controls (ignition on, kill switch normal, press flash button)?
« Reply #259 on: June 14, 2018, 10:34:15 PM »
I took the advice and bought a new light bulbs. Unfortunately not my issue, no light with the new bulb. Where should I go from here?
In a more positive note I was able to remove the exhaust shield after the last person to work on this Brick stripped out one of the bolts that held the shield on.
Supershooter
  • 85 K100 RT
« Reply #260 on: June 15, 2018, 01:53:25 PM »
Power for the headlight goes through the ignition switch, load shed relay and the left hand combination switch.  There are a number of connectors in the path where a loose or dirty connection can prevent light from getting out of the  bulb.
I would get an electrical diagram of the bike and start tracking the 12v from the battery to the bulb.
One tip.  I have found that it is easier to hear confirmation of power than to see it.  I say this because I am normally looking at where I am sticking the test probe, and it seems that every time I look away at my meter, the probe slips off the spot I want to test.  A buzzer or a horn will confirm the presence of power while still letting you concentrate on where you are testing.
« Reply #261 on: June 15, 2018, 02:09:53 PM »
... it seems that every time I look away at my meter, the probe slips off the spot I want to test.
Alligator clip leads are your friend, Jim.  A set of cheap alligator leads is around $5 - $10.  My personal favourite and what I recommend is the Fluke TP920 Test Probe Accessory set from Amazon.  Top quality product.
« Reply #262 on: June 15, 2018, 02:52:55 PM »
I have a ton of alligator clip leads, but still really like my little piezo box that does 12v and continuity testing.  One of the best pieces of kit I ever built.  It's especially nice when I am trying to test in the female half of small multi pin connectors where even mini alligator clips have a hard time.  Plus there is no need to have to position it so I can see a display, it can be anywhere and I'll hear the beep.
« Reply #263 on: June 17, 2018, 09:14:41 AM »
Well, during my test ride I hear the heat shield rattling, so I removed it. The P.O. stripped out a bolt head so I ground it off. Yesterday Dad and I sandblasted and repainted it. I’ll get back to the headlight issues after this diversion is over.
  • 85 K100 RT
« Reply #264 on: June 17, 2018, 04:52:52 PM »
If the rear master cylinder is leaking, there is a post for a easy swap to a Chinese alternative for $13.33 Au. Depending on the model you may have to swap the hose. At that price I even carry a spare in stock. Quite a few members are running them with no problems recorded so far in over 12 months.http://www.motobrick.com/index.php/topic,9364.msg90596.html#msg90596
« Reply #265 on: June 17, 2018, 10:43:18 PM »
Martin it's unfortunately the front. Preparation for new carpet got I the way of progress today, hopefully things slow down late this week.
The heat shield repair only cost $16.50 plus my free labor.
Supershooter
  • 85 K100 RT
« Reply #266 on: June 28, 2018, 09:47:52 PM »
Update,
My uncle stopped by yesterday and we made good progress on the headlight issue. We installed the new(used) ignition switch. He also helped me figure out that the high-low switch had gotten to hot at some point inthe past, ruining the switch. So I'll need a new left side switchgear. So are the Eureopean switchgear the same as the US switchgear? I find switchgear on eBay from overseas but nothing in the US.
We are also convinced that the master cylinder needs a rebuild kit. Any suggestions on the best place to purchase a rebuild kit? Beemerboneyard?
Supershooter
  • 85 K100 RT
« Reply #267 on: June 29, 2018, 12:20:11 AM »
There's one at kbikeparts.com right now. Here is a photo of it.
« Reply #268 on: June 29, 2018, 06:19:45 AM »
See if you can repair it first:  http://www.k100-forum.com/t174-headlamp-switch-repair
If not, the European switchgear for the left side is identical.  The European right side switchgear differs in that it has a headlight ON-OFF switch which is missing on North American models.
« Reply #269 on: June 29, 2018, 09:23:16 PM »
Laitch,
I found the switch you referred me to, will this one work for my 85 K100 RT? I'd prefer a plug and play but cut and solder may be an option if it has to be.
RBM,
I'm not sure fixing this switch will be in my wheelhouse, I appreciate the suggestion.
Supershooter
Left Combination Switch
61312305231
K1, K1100RS, K1100LT, R100GS, R100PD, R80GS, R80PD, R100MYS, R100R, R80MYS, R80R, R80GS/96
(I think model year 96+ K1100LTs had a built-in windscreen switch - this doesn't have that!)
  • 85 K100 RT
« Reply #270 on: June 30, 2018, 01:18:24 AM »
Laitch,
61312305231
View the text of the switch below that one. It explains how to graft that switch using your bike's connector. The windscreen switch offers possibilities for alternative uses. Fitment should be verified with the vendor. Posi-locks with heat-shrink tubing could be substituted for solder connections. As rbm has indicated though, left-side Euro switches should work with your bike.
« Reply #271 on: June 30, 2018, 01:42:31 PM »
Thanks Laitch,
I can see the value of the additional switch now. Do you have a quick link to adding cruise with this type of switch?
Supershooter
  • 85 K100 RT
« Reply #272 on: June 30, 2018, 02:22:31 PM »
The following is a writeup on installing a cruise control on K75 / K100.  Same site as Laitch directed you to, but with the details of the cruise install.
 http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/eleccruise/eleccruise.htm
« Reply #273 on: July 01, 2018, 10:04:41 PM »
I'm not sure I can get the left side switchgear cord removed from the frame so buying a switchgear with an extra switch with be just fine. If I'm mistaken please let me know.
Supershooter
  • 85 K100 RT
« Reply #274 on: July 01, 2018, 11:15:54 PM »
You're being too cryptic for me to determine if you're mistaken. Let's just say you're mistaken anyway. :giggles
