Author Topic: Guess that K100 plug....  (Read 6592 times)
Offline Angus Macgyver
« on: November 29, 2016, 08:12:09 PM »
hi guys,
1985 k100 build.
After rebuilding the loom I am at a loss as to what connects to this plug....
Bikes left frame side.
2 wire plug
Green/black stripe wire
Brown wire
  • New Zealand
  • 1991 Ducati 750SS 1984 K100 cafe racer, 1991 K100 RS, 1986 Suzuki GV1400 Cavalcade, 1981 Suzuki 820 Katana
" The people are fickle and easily manipulated "
1702 officer of the Royal Navy of England.
1984 BMW K100 cafe racer
1991 BMW K100 RS
Re: Guess that K100 plug....
« Reply #1 on: November 29, 2016, 08:24:13 PM »
My guess is grip heaters.
« Reply #2 on: November 29, 2016, 08:32:00 PM »
Ok.
Thanks.
The bike originally had those, but I removed them.
None of those plugs on the aftermarket warmers match the bikes loom plug, so I suspect the previous owner, unable to find the matching plug, wired in his own version.
It was a horrible birds nest of wires which was why I threw them in the " no longer required " bin.
  • New Zealand
1991 BMW K100 RS
« Reply #3 on: November 29, 2016, 08:40:38 PM »
Ok.
Thanks.
Did I win a bottle of Techron—or a gift card for one?
« Reply #4 on: November 29, 2016, 08:48:08 PM »
 :mbird
Just good will to all men/woman  :2thumbup:
  • New Zealand
1991 BMW K100 RS
« Reply #5 on: November 29, 2016, 09:49:09 PM »
That's going up on eBay.
Offline johann.muller
« Reply #6 on: December 01, 2016, 07:20:48 AM »
Hi
I am not 100% sure where you are there, but I am thinking Choke light. The plug is on the left side around where I think you are and goes to a sensor on the throttle body. I need a bigger context picture.
All of the 2 prong switch connectors used the same plug as far as I remember. I had Clutch lever, Brake light, Choke that used the same plug and switch.
The only disconnected thing left when I finished rebuilding my 83 RS was the extra instrumentation connection for the volt and temp gauge.
  • Cape Town
  • 83 K100RS, 09 K1300R
My psychologist works from a pub, 100km away on twisty roads.
« Reply #7 on: December 01, 2016, 11:42:56 AM »
Hi
agree with JM.   choke (really "fast idle") light.  should be under tank, in loom just to the left of the center frame bar.
« Reply #8 on: December 01, 2016, 01:37:13 PM »
Hi
Ok thanks , I will check the choke switch block.
  • New Zealand
1991 BMW K100 RS
« Reply #9 on: December 01, 2016, 02:42:54 PM »
It is the connector for the heated grips.
It has the correct colour code (green/black and brown), choke is violet/white and brown.
It has the correct pin config (flat pins, arranged as a T), choke has round pins.
The choke connector is also in the picture, beside the connector in question.
« Reply #10 on: December 01, 2016, 03:57:32 PM »
Noted, thank you.
  • New Zealand
1991 BMW K100 RS
