Author Topic: K100 CAFE FIGHTER  (Read 192200 times)
Offline stellarkyle
Re: K100 CAFE FIGHTER
« Reply #75 on: March 01, 2017, 03:13:57 PM »
How much did ordering that from eMachineShop.com set you back?
  • Marietta, GA
  • 1985 Turbo K100RS; 2001 F650GS
Offline Boxermann
« Reply #76 on: March 01, 2017, 03:15:22 PM »
Ca 90 usd + shipping.
  • K100 / '87, K75 / '87
« Reply #77 on: March 01, 2017, 03:28:52 PM »
Pretty good price for a one off machined piece of kit that will look super cool and really raise the level of the bike
Offline Elipten
« Reply #78 on: March 01, 2017, 04:39:58 PM »
 That is fantastic.  Even an old dog can learn new tricks.
  • San Antonio, TX
  • 1990 K75RT
Offline milq
« Reply #79 on: March 01, 2017, 07:04:28 PM »
Agreed! I'd be hard pressed to make it for that money. If I wanted to make money anyway.
  • Southern IL
  • 1988 K75S
Offline Boxermann
K100 CAFE FIGHTER
« Reply #80 on: March 02, 2017, 02:19:16 AM »
If you team up with somebody the price drops pretty fast though. If you make two at the same time they cost $50 each, three $35 each and so on.
You can opt to powder coat, anodize, bead blast, etc for a little addition in cost too. I chose 6061 grade aluminium, but they also have steel, brass, titanium... I think even silver or gold if you want.
Offline nods
  • Sydney, Australia
  • 1985 K100 RT
« Reply #81 on: March 02, 2017, 02:42:53 AM »
What a great business idea, well done to them.
Sent from my SM-G925I using Tapatalk
  • Sydney Australia
  • 1985 K100 RT
Offline milq
« Reply #82 on: March 02, 2017, 07:20:29 AM »
No, I meant as a machinist, I would likely charge more than that for a one time part. But I don't have a water jet, so I would make that part with wire EDM...which gets $100/hr to run.
  • Southern IL
  • 1988 K75S
Offline MaraudeRS
« Reply #83 on: March 02, 2017, 10:21:12 AM »
I want one!!! Without the center cut out. You should sell them on eBay, I want one bad!
I'd be in for one too (without the cutout) if you want to order one JC. Lmk
  • Monterey, CA
  • 1992 K100RS
Offline jc55
« Reply #84 on: March 03, 2017, 03:56:10 PM »
Yes I do. And we need to give Boxermann the chance to make some money on this idea.
  • Carrollton, Ohio
  • '90 K100LT '77 Gl1000
Offline Boxermann
« Reply #85 on: March 03, 2017, 04:37:03 PM »
No worries. Just glad to help. I only need to know what shape you want it on the top side. Flat like the illustration below to cover the fairing mounts?
Painted mine glossy black, and I couldn't be happier with the result.
Offline jc55
« Reply #86 on: March 03, 2017, 04:39:38 PM »
That's gorgeous. I'd like one notched like yours...not straight.
  • Carrollton, Ohio
Offline Mike Flores
« Reply #87 on: March 03, 2017, 10:07:37 PM »
Boxermann, you're bike is coming along nicely! That motoscope pro is looking really good too!
  • Los Angeles, CA
  • 1987 K100
Offline Boxermann
« Reply #88 on: March 06, 2017, 04:03:44 AM »
Thanks! Just PM me your email address and I'll send you the file.
Thanks Mike!
Still working on the frame. Needs a little more sanding, but soon ready for paint. Also started making a mold for a fiberglass cowl.
(... and yes, my garage is a complete mess right now)
Offline MaraudeRS
« Reply #89 on: March 07, 2017, 09:54:34 AM »
Yea the notched looks really good. I'll PM you my email address too and JC and I'll will get together on this. Thanks!
  • Monterey, CA
  • 1992 K100RS
Offline jc55
« Reply #90 on: March 07, 2017, 09:59:19 AM »
It's looking good. You're making quick progress. The frame shooting is coming along.
  • Carrollton, Ohio
Offline Boxermann
K100 CAFE FIGHTER
« Reply #91 on: March 11, 2017, 03:39:31 AM »
Made the center hole in the nut a little bigger so I could fit the control button for the motoscope inside rather than on top. Happy with the result so far. I probably should have covered the holes for the forks before painting the trees though..
Fabricated a mount so I can place a cone air filter on the AFM. Paint finish didn't turn out great since I managed to drop it on the dusty floor, but I don't care. Its barely visible when mounted anyway.
Offline jc55
« Reply #92 on: March 11, 2017, 10:19:18 AM »
Your pictures are way too big...I can hear the bandwidth sucking through my phone!
  • Carrollton, Ohio
Offline Boxermann
« Reply #93 on: March 11, 2017, 10:33:02 AM »
Sorry, I've shrunk them now. I blame Tapatalk. :)
Offline jc55
« Reply #94 on: March 11, 2017, 10:37:33 AM »
Oh that's much better! So, no details on the MAF adaptor fabrication? That looks great. I have an edge roller, but I never tried to put a bead in the end of tubing yet.  :2thumbup:
  • Carrollton, Ohio
Offline Boxermann
« Reply #95 on: March 11, 2017, 10:57:10 AM »
Not that much to it. Just made a plate in aluminum (I had it cut out at the same time as the triple tree plate) and attached a piece of 60mm tube on it. I was planning on using brazing sticks, but I couldn't get that to work properly so I ended up using a strong epoxy instead. The aluminum didn't look that great after my failed brazing experiment and the epoxy job was kind of messy, that's why I painted it.
Offline Boxermann
« Reply #96 on: March 11, 2017, 11:02:51 AM »
Found pics.
Offline jc55
« Reply #97 on: March 11, 2017, 11:28:08 AM »
That really looks great, man. I need to expand my horizons and get into more machining. Thanks for sharing!
  • Carrollton, Ohio
Offline Boxermann
K100 CAFE FIGHTER
« Reply #98 on: March 11, 2017, 11:32:01 AM »
Thanks.
If you want to use a 3" cone filter you could probably make one of these fit after some lighter modification:
http://www.ebay.com/itm/88-92-Golf-Jetta-1-8-2-0-Mass-Air-Flow-Sensor-Adapter-/140522647308
Offline Boxermann
K100 CAFE FIGHTER
« Reply #99 on: March 13, 2017, 03:36:40 AM »
Making an intake manifold and doing the last touches on the mold for the cowl before glassfiber. I've ordered a custom led strip from Radiantz that is going to go in the groove in the frame.
