Author Topic: Project Apokalypse  (Read 66409 times)
Offline furnimoto
Re: Project Apokalypse
« Reply #25 on: December 14, 2016, 10:11:50 PM »
So, I finally got around to doing a progress update video:
 I'm almost done with the foot controls, all I have to do is machine a new brake pedal, a return spring and adjustable stop, and a mounting plate for the master cylinder. I'm pretty happy with how they turned out.
I have all of the components for my handlebars, and soon I'll be ready to tackle some of the rewiring. I am relocating the battery as well as the relay box, and using a motogadget m-unit v2. It's going to be a pretty cool setup.
The main obstacle that I am up against currently is the mounting of the headlight. So far I haven't come up with any designs that I am happy with. I will probably try to work iteratively, getting something in place even if it isn't the final design will be pretty useful to working through the problem I think.
  • Oakland, CA
  • 1996 bmw k1100rs, 1973 bmw r75/5, 2015 ducati diavel
Offline furnimoto
« Reply #26 on: December 15, 2016, 03:37:29 AM »
Check out this ridiculous youtube channel trailer I made for Project ApoKalypse, it's pretty rad
...and I'm going to give away a pair of the bar risers I made. It's entirely conceivable that I will get no entries from youtube, so I thought someone here might be interested. Click the title of the video to go to the youtube page and leave your links there
  • Oakland, CA
« Reply #27 on: December 15, 2016, 08:47:25 AM »
By rad, you mean radioactive?
Offline Glacial
« Reply #28 on: December 15, 2016, 10:33:53 AM »
Laitch - you are so not down with the kids :oldguy:
  • Cambridge, UK
  • 1990 K75S VIN 0109678
Offline The Dude
« Reply #29 on: December 15, 2016, 12:28:58 PM »
Free radicals?
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #30 on: December 15, 2016, 12:30:33 PM »
Yo  bro. :2thumbup:
Offline MaraudeRS
« Reply #31 on: December 15, 2016, 12:48:21 PM »
I have a build on here. Can I link it as my entry? Those bar risers are SWEET!
  • Monterey, CA
  • 1992 K100RS
Offline furnimoto
« Reply #32 on: December 15, 2016, 03:52:50 PM »
Of course! If you post a link, you will be the current winner since you would be the 1st entry
  • Oakland, CA
Offline MaraudeRS
« Reply #33 on: December 15, 2016, 04:59:08 PM »
Excellent! Just posted but not sure if the link works. I'm Dom Yan and mines the Rusty Brick project
  • Monterey, CA
  • 1992 K100RS
Offline furnimoto
« Reply #34 on: December 15, 2016, 06:50:22 PM »
It worked, so far you are the only entry, and the current winner
  • Oakland, CA
Offline D.Bachtel
« Reply #35 on: December 15, 2016, 08:33:30 PM »
What are your plans for the original bars Furni?
If they're wider than the ones on my K75C I'd sign up for that raffle!
They bar risers certainly look swell, even if you still need to mount it together with the originals.
Don in Nipomo
  • Nipomo
  • BSA, Zundapp, Husqvarna, Greeves, Triumph...and a 1987 K75C
Offline furnimoto
« Reply #36 on: December 16, 2016, 02:21:02 PM »
Don in Nipomo
Don, They are 27 inches wide. I don't know if that is wider than your k75 bars, but if you're interested I would happily sell them to you for cheap. Make me an offer and I will most likely accept it
  • Oakland, CA
Offline furnimoto
« Reply #37 on: December 16, 2016, 02:21:47 PM »
oops, sorry for the upside down pic
  • Oakland, CA
Offline D.Bachtel
« Reply #38 on: December 16, 2016, 10:19:27 PM »
Heres a right side up but backwards of my bars.
They might even be wider than yours allowing for the antivibration dongles inserted in the ends.
I'm looking for the bars that measure 27" before we start adding grips and bumper knobs.
What I want is to spread out my grip a bit. I'm use to wide bars.
Don in Nipomo
  • Nipomo
Offline furnimoto
« Reply #39 on: December 18, 2016, 03:04:00 PM »
Sounds like my bars are not going to be the right solution for you. The new handlebars that I installed are much wider than the stock ones were, maybe an aftermarket solution would work for you?
  • Oakland, CA
Offline D.Bachtel
« Reply #40 on: December 18, 2016, 09:37:13 PM »
I believe you are correct. What I'd like to try is a set of K1 bars. Just an inch or so on each side with a bit more pullback.
Metric motocross bars might work,  I've got a set of thick walled aluminum Honda CR 250s on my Zundapp 601.
Fairly flat and low rise for eventual sidecar work. They measure 32" tip to tip on the surgical rubber Maguras.
Be sure to post up your castoff, salvage parts on the board.
Seems like half the folks here like to take their Ks apart while the other half are trying to put them back together!
Don in Nipomo
  • Nipomo
Offline Glacial
« Reply #41 on: December 19, 2016, 02:19:02 AM »
Don in Nipomo
Good summary!
  • Cambridge, UK
Offline furnimoto
« Reply #42 on: December 23, 2016, 03:51:40 PM »
Here is a video of some of the machining I did on the footpegs set to my favorite Nancy Sinatra cover of all time
  • Oakland, CA
« Reply #43 on: December 23, 2016, 06:37:05 PM »
. . . my favorite Nancy Sinatra cover of all time
Finally—a version of that song that isn't painful to hear! :clap:
Offline furnimoto
« Reply #44 on: December 23, 2016, 10:28:49 PM »
Haha, I should have mentioned that the all time favorite list of Nancy Sinatra cover tunes begins and ends with the Megadeth version of "these boots"
  • Oakland, CA
Offline furnimoto
« Reply #45 on: January 16, 2017, 03:27:55 AM »
Here are the results of the bar riser giveaway I did on youtube, Congratulations MaraudeRS!
  • Oakland, CA
Offline Boxermann
« Reply #46 on: January 16, 2017, 06:53:20 AM »
Great machining and soundtrack!
BTW, what speedometer is that?
  • K100 / '87, K75 / '87
Offline MaraudeRS
« Reply #47 on: January 16, 2017, 11:32:50 AM »
Woohoo! Thank you very much! What do you need from me besides my address? I can PM you
  • Monterey, CA
  • 1992 K100RS
Offline furnimoto
« Reply #48 on: January 16, 2017, 03:06:57 PM »
Your welcome! I'll cover the shipping all I need from you is your shipping address. I hope you enjoy them, I'm going to ship them out with some black oxide socket head cap screws(all I had at the shop), but I recommend that you get some hardware that won't rust.[size=78%] [/size]
  • Oakland, CA
Offline furnimoto
« Reply #49 on: January 16, 2017, 03:11:05 PM »
Thanks. You mean the speedo in the giveaway results video? It is the stock speedo on my 2015 ducati diavel. I did order this sweet motogadget tach/speedometer from revival cycles for project apoKalypse though, but they seem to be having some supply chain issues and it hasn't arrived yet.
https://revivalcycles.com/collections/for-your-ride-motogadget-gauges/products/motogadget-chronoclassic-tachometer
  • Oakland, CA
