Author Topic: K100RS parked for four months outside in all weathers  (Read 314435 times)
Offline The Dude
Re: K100RS parked for four months outside in all weathers
« Reply #550 on: June 01, 2017, 07:33:48 PM »
+1 you can do it.
Tinkering will give way to strict methoding.The method is designed to progress through the task with no room for error.Apart from the maths calculating the new bucket size in each case and ensuring the cam timing is returned as it was,it will be pretty straight forward.Keep it clean.
I would consider not riding until sorted to preserve the valve face life.
All the best.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #551 on: June 01, 2017, 09:54:26 PM »
A good engineering shop ( if such a thing exists in your area) should be able to lap them down. They should be able to do it without effecting the surface hardness if there is only minor wear.
« Reply #552 on: June 02, 2017, 08:54:44 AM »
The main hurdle I need to overcome is the minister of finance, she who must be obeyed, I get very stern looks every time I come home with a box marked MaxBMW...  :hehehe
Have you tried bribing her with the M&M's?  "Look, honey, I got you some M&M's, and they even included some parts for the bike!"
Offline Filmcamera
« Reply #553 on: June 02, 2017, 08:56:53 AM »
Genius!
It shall be done...
Maybe I can get MaxBMW to send red wine instead, then I would be golden
  • San Jose, Costa Rica
Poserbricker
« Reply #554 on: June 02, 2017, 09:38:08 AM »
If that doesn't work, get a couple of packages from Tom of Finland. She'll be glad to see only MAXBMW boxes after that.
Offline Filmcamera
« Reply #555 on: June 08, 2017, 07:31:25 PM »
LOL Johnny you crack me up - so funny!  :clap: :hehehe :2thumbup:
Poserbricker
Offline Filmcamera
July 4th breakfast ride
« Reply #556 on: July 04, 2017, 02:50:57 PM »
My wife and I took advantage of it being a day off to have a rare midweek morning ride for breakfast before the rain came down.
Lovely ride, beautiful weather and great scenery.
Happy 4th to you all
Bike is running great!
* July 4th ride.jpg (43.72 kB . 768x432 - viewed 623 times)
* GOPR1956-view.jpg (43.49 kB . 768x432 - viewed 640 times)
* GOPR1956-cg.jpg (62.32 kB . 768x432 - viewed 636 times)
Poserbricker
Re: July 4th breakfast ride
« Reply #557 on: July 04, 2017, 06:21:39 PM »
Nice!  great way to spend the morning!
« Reply #558 on: July 04, 2017, 08:23:42 PM »
that last photo... is that you or your wife...
Offline Filmcamera
« Reply #559 on: July 04, 2017, 08:40:05 PM »
My wife - but I appreciate you thinking that at 52 I might have skin like that - or is it just time for an eye check up?
Poserbricker
Offline Filmcamera
« Reply #560 on: July 21, 2017, 01:41:26 PM »
Today I got my new low seat - a Russell I think - a big thanks to diesis.
it looks great and she who must be obeyed says it is much more comfortable.
Next job - raise the foot pegs for her.
* 20170721_112052-1008x756.jpg (73.75 kB . 768x576 - viewed 737 times)
Poserbricker
Offline Filmcamera
« Reply #561 on: July 25, 2017, 06:49:07 PM »
I finally got round to making the foot peg risers so my petite wife can sit more comfortably on her new Russell seat.
No major issues except I had to angle them forward when I put on the tragkorbs because they were too close otherwise, giving her no heel room.
* 20170725_163651-756x1008.jpg (43.07 kB . 432x576 - viewed 690 times)
Poserbricker
Offline Filmcamera
Re: Random Ride Photos ~ Where Did You Rode Your Motobrick Today ?
« Reply #562 on: July 27, 2017, 06:08:32 PM »
I played hooky today and went to Manuel Antonio to see my cousin who is here on vacation.
It has been 30 years since we met so I think I am ok in skipping work to see him!
Great ride down in the morning, clear and cool and the bike running like a champ.  Less fun on the way back, very muggy and I got rained on pretty hard.
Worth it though for sure!
https://a.rever.co/embed/rides/589698 here is a map from a new app I am trying
EDIT: BTW my new Russell seat is just brilliant. 4+ hours of saddle time and I got off fresh as a daisy!
* 20170727_105520-1008x756.jpg (46.55 kB . 768x576 - viewed 639 times)
* Screenshot_20170727-161356.jpg (21.93 kB . 324x576 - viewed 599 times)
Poserbricker
Offline Filmcamera
Oil usage?
« Reply #563 on: July 28, 2017, 10:49:28 AM »
A have a quick question about oik usage as I am still fairly new to my bike ad am not sure what is normal usage for a 26 year old brick.
I did a 200 mile ride yesterday in hot weather but at normal revs, cruising at around 5000 rpm.
I checked the oil before I went and it was at exactly the right level. When I got back I let the bike cool down for an hour or so and checked again, the oil level was at the very bottom of the sight glass.  It took I would estimate one third of a quart or so to get it back up to the correct level.
So given my bike has at least 125,000 miles on the clock (I say at least because the speedo and odometer were not working when I got it and said 123,000) does that sound like a high amount of oil to use?
Poserbricker
Re: Oil usage?
« Reply #564 on: July 28, 2017, 11:59:17 AM »
that seems pretty high.  most k's I've seen don't use more than 1/2 quart between 5000mile changes.  high usage is not necessarily bad as long as you don't let it get too low.
Offline Revrdmark
Re: Oil usage?
« Reply #565 on: July 28, 2017, 01:07:17 PM »
That seems a bit high to me as well. It seems that if it were using/burning oil at that rate you would see at least some blue smoke from exhaust. If you didn't see any I would check for leaks. Old bikes ( BMW and others) tend to leak around drain plugs a thicker washer is usually an easy fix. The gaskets around the filter case and the gasket around the oil pump on the front right of the engine are usually culprits as well. If it ran ok I'd just chuck it up to one of the joys of riding a 25 year old bike and keep a few quarts on the shelf and check it before you head out to ride.
  • Spokane WA
  • 87 K100
Re: Oil usage?
« Reply #566 on: July 28, 2017, 04:16:43 PM »
Bricks don't like sitting, and it seems due to the design of the engine if left sitting for long periods the rings can become sticky. You can either run a high detergent oil briefly to unstick them or just ride it until the rings free themselves up. A mates Brick was prodigious smoker when he first got them it. It had been sitting for long periods of inactivity, however it eventually settled down, and now only smokes after being left on the side stand.
Re: Oil usage?
« Reply #567 on: July 28, 2017, 07:38:47 PM »
:2thumbup:
If you aren't seeing clouds of blue smoke in the air or pools of oil on the ground, don't worry about it. Check it before the day's first ride and avoid overfilling it.
Offline Filmcamera
Re: Oil usage?
« Reply #568 on: July 28, 2017, 08:50:28 PM »
Great thanks everyone.
I have new hoses etc for the throttle bodies on the way and when they I fit them I think I might take off the valve cover again and be a little more liberal with the silicon when putting it back, I have the impression the bikes runs marginally hotter than before I checked the valve clearances and uses a little more oil so it could be there is a very slight leak, though no pools of oil on the floor.
Poserbricker
Re: Oil usage?
« Reply #569 on: July 28, 2017, 10:38:12 PM »
These brick engines like to hide oil...
point in case... I check mine daily before I pull it out of the garage. Normal level is at the dot.
One morning it was at the low level line, ok, so I filled it half way up to the dot, knowing it likes to hide oil.
Next day it was up to the dot. 2nd day it was now almost at the upper limit line.
Since then it has been between the upper level line and the center dot, slowly working it's way back down.
I've had the levels fluctuate up and down quite often.
As long as it is above the low level line, don't be over zealous in overfilling it, above the center dot.
Re: Oil usage?
« Reply #570 on: July 29, 2017, 09:45:44 AM »
I have a K100RS4v sister ship with 120,000 miles.  It sat for a couple years before I got it, and it appeared to not have been very well maintained before that.
This bike uses oil, a lot more oil than my K75's that go at least 3-4 thousand miles on a quart of oil.  When I got it, oil usage was about a quart every 6-700 miles.  While it doesn't smoke after the engine warms up, I have been told there was a definite scent of oil when other riders followed me.
Compression is good and uniform across all cylinders, so I didn't suspect rings.  I replaced the valve guide seals, and the head gasket.  Oil consumption decreased slightly to about a quart every 850-900 miles.  Better, but not as good as my other bricks.  I replaced the rear main seal and the o-ring which was leaking when I did the seals.
Right now I am thinking the oil control rings are shot.  I have put over 12,000 miles on the bike now and done Seafoam flushes and use Rotella T6 with no further improvement.  At the rate the bike uses oil, I can buy enough T6 to keep the oil topped up for about 50,000 miles for the cost of parts for doing the rings.  Why bother to fix them?
My daily commute is about 105 miles, and every morning I add about 4oz. of oil as part of my pre-ride check.  No big deal.  I also carry a 12 oz. bottle of oil in the cowl for longer trips.
Offline Filmcamera
Re: Oil usage?
« Reply #571 on: July 29, 2017, 09:48:12 AM »
Yeah that sounds very like my bike.  OK I will not fuss about it too much for now and just see how things develop.
Poserbricker
Offline Filmcamera
Re: Oil usage?
« Reply #572 on: July 29, 2017, 10:46:16 AM »
Hey TMG another quick question if I may.  I do not have a steering damper on my bike, do you have yours still? I found a secondhand one for about $80 but i am not sure whether I really need it so I wanted to ask before buying it.  Any thoughts?
Poserbricker
Re: Oil usage?
« Reply #573 on: July 29, 2017, 11:25:08 AM »
Offline Filmcamera
Re: Oil usage?
« Reply #574 on: July 29, 2017, 01:00:32 PM »
Greetings...
Thanks once again for your sage and invaluable advice.
I shall, as always, give it the importance and weight it deserves.
Poserbricker
