Author Topic: 95 K75 idles but won't stay running  (Read 16202 times)
Offline The Dude
Re: 95 K75 idles but won't stay running
« Reply #25 on: July 02, 2017, 03:38:24 AM »
So,Casey,was it the AFM? :dunno
These threads die when the AFM is arrived at....must be a clue aye?
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline caseyvr6
« Reply #26 on: September 22, 2017, 12:52:03 PM »
Looks like no...
next step is the main pin-to-pin checks on the ECM. The level of patience may turn into $$ for the dealership to run the scan instead.  :dunno
  • Catskills, New York
  • 1995 K75
Offline The Dude
« Reply #27 on: September 22, 2017, 02:11:06 PM »
You're on my time scale,caseyvr6.keep going.It's just a machine.
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #28 on: September 22, 2017, 03:33:00 PM »
That's what they said on the Titanic—although substitute iceberg for machine.  :yes
Offline caseyvr6
« Reply #29 on: July 31, 2018, 07:06:15 PM »
After a winter of on-off-on tinkering, I had started testing the 3 separate computers with frustratingly slow progress when moaning to a friend. He said, all matter-of-fact, "sounds like a vacuum leak" and I laughed at him. A week later, I ordered up the line for $10 from the 3rd carb to the fuel pressure regulator, installed it today. I turned the key just to confirm it didn't work and the bike roared to life and purred like a whiny little kitty.
Problem solved, $10 vacuum line.  :imwithstupid:
  • 1995 K75
Offline beemuker
« Reply #30 on: August 01, 2018, 09:28:26 AM »
The whole business is found in this document. Scroll down to it. I'd give you the exact page number but it doesn't have any page numbers.
hmm
This site can’t be reached
hrsbstaff.ednet.ns.ca’s server IP address could not be found.
  • Panama City, FL
Offline blackie1
  • christchurch nz
« Reply #31 on: August 04, 2018, 03:22:56 AM »
and kennybobby is the winner in his diagnosis in reply 15
"The fuel pressure regulator may be stuck open such that the fuel pressure is too low to sustain running above idle speed or when the motor has a load on it.  There is a vacuum line that controls the pressure that is probably cracked if it hasn't been changed recently, it would cause the mixture to run rich."
 :clap:
  • 1991 K75RT naked 67,000kms
Tags: answered
