Author Topic: Inaccurate gas warning light  (Read 25900 times)
Offline White Dog
« on: September 07, 2016, 09:37:41 PM »
In the few months I've been on this forum, I remember a post on how to change something inside the gas tank to delay or speed up when the low gas warning light comes on.  Mine seems to be about 50 miles early.  I've calculated mpg almost every fill up and I should be able to go 180-200 miles before the light comes on.  Yeah, I know.  I can leave it alone and just go by the odo but I am curious to know how to correct this annoyance.  have not been able to find the write up.  Can someone point me to it?
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Offline jaxon
Re: Inaccurate gas warning light
« Reply #1 on: September 07, 2016, 09:59:01 PM »
One suggestion was light bending the float rod down a bit.
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
« Reply #2 on: September 07, 2016, 11:28:55 PM »
. . .  I remember a post on how to change something inside the gas tank to delay or speed up when the low gas warning light comes on. . . . Can someone point me to it?
Is this it, White Dog?
Offline White Dog
« Reply #3 on: September 08, 2016, 07:34:05 AM »
Yep.  That's the one.  It was "over my head" when I first read it and it still is.  Note there are no instructions for actual removal of the sending unit from within the gas tank.  I also recall reading somewhere how to remove the sending unit but could not find it, either.  Me thinks I will just rely on the odometer reading and try to ignore the low gas yellow light glaring at me.  The tank is listed as 5.2 gallon capacity.  Using 4.5 gallons as reference divided by a conservative 40 mpg, I should be able to travel 180 miles before getting concerned about refilling the tank.
One thing I failed to mention is last night, the light came on at 132.5 miles but went off at 132.7 miles, so that tells me I cannot depend on the light.  I did fill up--took 2.85 gallons.  Of the 3 cycles I own, the BMW is the only one without a gauge to view and with an inconsistent low gas light, I'm thinking a piece of black tape over the light is an easy fix.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
« Reply #4 on: September 08, 2016, 08:11:20 AM »
There are four screws on the bottom of the tank that holds the fuel sender in place.  Remove those screws and the sender will be able to come out the filler cap opening (once the filler cap is removed; four screws there also).
Once you have it out, check that the float bulb is still intact.  Your inconsistent readings might be due to the bulb having a hole in it that is allowing gas to leak in.  I'm pretty sure you should be able to find a substitute bulb if your's has gone south.
The adjuster wheel is hidden but searching under the actuator arm will soon reveal it to you.
« Reply #5 on: September 08, 2016, 12:43:17 PM »
Ahhh....0.2 miles is not inconsistent.  Gas is a liquid.  It moves.  The level changes with lean, acceleration and decel. The sensor is a float.   It moves with the level.   It is reliable.
You dont need to take anything apart to adjust.  Just reach in and bend the arm.
« Reply #6 on: September 08, 2016, 12:46:34 PM »
Just because the tank says 5.2 does not mean it is all usable.   The fuel pump will loose suction long before 5 gal are used.
If you manage to use 4.5 gallons,  you had better be sitting in front of a gas pump refilling. ...
Offline White Dog
« Reply #7 on: September 08, 2016, 01:26:47 PM »
So you agree that the arm should be bent down?  This would lower the float, resulting in the light not coming on until there is less gas in the tank?
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
« Reply #8 on: September 08, 2016, 02:53:46 PM »
You don't have to bend the arm to adjust the float arm. There is a toothed wheel which you lever around with a small screwdriver.
« Reply #9 on: September 08, 2016, 07:02:54 PM »
Impossible....as the mounting plate is mounted on the outside of the bottom of the tank, and is is much
bigger than the hole in the bottom of the tank.
The pot.meter, arm and float have to be pulled out through the bottom hole.
« Reply #10 on: September 08, 2016, 07:59:03 PM »
You're right inge.  It's been a few years since I pulled the sensor from my tank.  Poor memory.
Offline Mwilson904
« Reply #11 on: September 09, 2016, 05:51:08 PM »
I have mine apart, here's a pic maybe it will help you send where to bend it.
  • Fort Myers, Florida
  • 1986 K100
Offline White Dog
« Reply #12 on: September 09, 2016, 07:09:30 PM »
Thanks for posting the pic.  I'm guessing the longer rod which has the bulb on the end should be bent down as it lays in the pic?
If I have to remove the unit in order to bend the rod, I might as well do what several have mentioned and turn the wheel counter clockwise to lower the bulb.
In either case, I currently have a full tank of gas and can't do anything until I run the tank almost dry.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline Mwilson904
« Reply #13 on: September 09, 2016, 07:30:31 PM »
***Yes (with disclaimer)  If you plan to leave it in the tank and bend it, I would remove the 4 screws on the gas cap base and remove it, this allows you to get your hand in the tank, then you can feel the rod and lift it up and down (similar to the movement of gas) allowing you to figure which direction it rotates, then bend the rod between the bulb and the first bend in the rod.
***I've owned a BMW bike for about 1 week and it does not run therefore you may want to get a second opinion  :hehehe
  • 1986 K100
« Reply #14 on: September 09, 2016, 07:40:16 PM »
Use the wheel, that's what it is for. :nono If you use the force you will go to the Dark side.
Offline champ7fc
« Reply #15 on: September 09, 2016, 08:00:42 PM »
Anytime I read the posts on this forum regarding fuel quantity indicators I have to smile. I have been a pilot for 45 years and the last gauge any pilot ever trusts is his fuel gauge. This applies to my motorcycles. The K75S I own has a gauge, I use it for reference only. When I leave on a ride I check my fuel visually and reset my trip meter to 0. I know my estimated range on the fuel visible in the tank and when I have reached the half way point I look for fuel. Seems to me alot of time and effort is expended on a rather useless indicator. Just my two cents worth. Craig
  • Staffordville, Connecticut
  • 1987 K75S, 1985K100RS
Offline Mwilson904
« Reply #16 on: September 09, 2016, 08:29:30 PM »
Listen to Martin and/or Craig, with mine in hand I don't see a screw (may have deteriorated away)
I just dry fitted it back in the tank to see how it sits, If it doesn't read right when I'm done, a visual is always best.
  • 1986 K100
Offline The Dude
« Reply #17 on: September 09, 2016, 08:30:56 PM »
+1
Bricks are too heavy to push far.Ive never run out....
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #18 on: September 09, 2016, 08:48:15 PM »
To which screw are you referring, Mwilson? Or is it the toothed wheel you can't find?
Offline White Dog
« Reply #19 on: September 09, 2016, 08:53:58 PM »
From an  earlier post above.
"The adjuster wheel is hidden but searching under the actuator arm will soon reveal it to you."
I presume if you turn this adjuster wheel, you should see the bulb rise or fall.  If it falls, the indicator light would not come on as quickly.  I personally do not know how much the adjuster wheel should be turned to delay the warning light coming on.  The Clymer manual states how to R/R the sending unit but NOT how to change the wheel setting (which the book says the light comes on with 1.3 gallons left.  Adjustment of the wheel (and pictures) is in the  first post by Laitch.  Bending the rod seems risky, as the book and these guys say "Don't do it."
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline Mwilson904
« Reply #20 on: September 09, 2016, 09:37:15 PM »
Laitch, Sorry, I missed the link earlier showing The disassembly and refurbishing of the unit.  Now I see it, looks like a great project after I get this thing running but take it back apart if I decide to do a repaint.
For now, I'll just clean it up and start to get this thing back together.
Thanks!
  • 1986 K100
« Reply #21 on: September 09, 2016, 09:47:17 PM »
I chased up a picture of the toothed wheel. :2thumbup:
Offline kennybobby
« Reply #22 on: September 09, 2016, 10:11:25 PM »
No the bulb doesn't move--the adjuster just moves the electrical contacts inside the sensor that signals 4L remaining.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
Offline White Dog
« Reply #23 on: September 09, 2016, 10:20:52 PM »
How many teeth should be moved to delay the light from coming on at 1.3 gallons left? My light comes on with 2.3 gallons still in tank. That would be about 40 miles on my cycle.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
« Reply #24 on: September 09, 2016, 10:35:30 PM »
AAAAAARHG!!!  23 post to bend a stupid rod.  (or turn Martin's screw)  Bend it, screw it, ride it!
