Author Topic: second gear slippage question - 90 k75  (Read 17142 times)
Re: second gear slippage question - 90 k75
« Reply #25 on: August 25, 2016, 02:22:33 PM »
How're the valves looking on your 200k bike, Chaos? Original engine still, original top end, and some clearance left still?
Offline The Dude
« Reply #26 on: August 25, 2016, 02:45:25 PM »
I recently checked my shims and have at least 0.5 mm of shim reduction potential left after 160,000 miles.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #27 on: August 25, 2016, 03:46:59 PM »
All original, some of the intakes still have their original shims I think.  Last adjustment I replace 2 exhaust valves, don't remember exactly but not close to running out of clearance yet.  Usually that's only a problem if they run tight for too long.  Did replace the shift drum and shift forks around 100k, early transmissions had bad heat treatment or some issue there.
Offline allisonmo2
« Reply #28 on: August 25, 2016, 03:50:06 PM »
i was aware of the mileage, but not too concerned, if that makes sense. 10k/year does mean it is ridden. always a good sign. no worries....the hunt continues......
  • hanover, pa
  • none as of yet. (bmw that is)
