Author Topic: 87 K75 Complete Rebuild  (Read 50486 times)
Offline Vespa no more
Re: 87 K75 Complete Rebuild
« Reply #25 on: September 09, 2016, 04:16:53 PM »
The standard of your work seems to be of a high quality. I suppose for many on this forum, it's reassuring to see that the bike is in the hands of someone competent and that the finished product will be impressive. Keep the pics coming.
Have you got an idea of costs so far?
Now about that air conditioner in the garage...
Regards
Guy
  • Wollongong NSW AUSTRALIA
Offline frankenwing
  • Bolted • Brewed • Originals ☠ ☕ 🏍
« Reply #26 on: September 09, 2016, 04:24:31 PM »
Thank you sir. I appreciate that.
Bought the bike for $650. Running but in pretty rough shape. Most of the costs so far have just been in maintenance/replacements. I'm very much a DIY kinda guy, and whatever I haven't done yet I try to learn how to do it myself. So as far as the cosmetics are concerned, the only thing I've outsourced was powder coating. I got the wheels and frame done together for $240 (remarkably cheap). I'm maybe under $600 total so far (including powder coat). All the littles things add up: filters/gaskets/o-rings.
Fortunately I have a fairly decent stock pile of random parts and accessories that worked really well for it. I had an extra set of R90 bars to replace the bent up and rusty ones that were on the bike. 👍🏼
I love it 😁
[ONE-OFFS]
1976 GL1000 Bobber // 1987 K75
« Reply #27 on: September 09, 2016, 04:37:36 PM »
Yes the rubbers are a perishable - as stated numerous times elsewhere on this forum.
Sometimes you might be lucky and recommission old rubbers with little problems. Other times, best policy might be to replace all the usual suspects (esp those relating to the fuel system - it is fuel injected and this operates under pressure). I guess most of us walk the line in between - replace the obvious, rebuild the bike and then find out what else is causing problems (eg. crankcase breather hose ... cheap .... throttle body to engine head inlet rubbers ... expensive).
Laitch has voiced his doubts about idle bikes (ie off the road for some time) ahead of used old bikes. I guess the rubbers benefit from being used and maintain pliability.
Any idea on what changes in rubbers - do they dry out? or is there some chemical change?
Question for all:what is the best rubber salve we have found that will maintain rubbers ... will paste a copy of this question as fresh topic.
Guy
Offline frankenwing
« Reply #28 on: September 09, 2016, 04:45:19 PM »
Just yesterday I had new brake lines made. Partially because the R90 bars I put on somehow set the master cylinder too far away from the steering stem. And today i just bought 3 meters of fuel line to replace all of them. I agree, its better to just replace it all if it's been sitting awhile. Eliminate any vacuum leaks right off the bat.
[ONE-OFFS]
Offline frankenwing
« Reply #29 on: September 09, 2016, 05:02:39 PM »
Just about finished modeling the dash kit for Fuel/Temp Gauges, ignition switch, and hazard/fan/aux power/ switches. I absolutely love having a 3D printer 😁
[ONE-OFFS]
Offline TrueAce
« Reply #30 on: September 09, 2016, 05:35:22 PM »
Impressive! :riding:
  • Florida
« Reply #31 on: September 11, 2016, 04:22:37 AM »
How big is this 3D printer?
Perhaps we can have a #D printer model recommendation.
The school I work at has several and all they seem to make is shitty little key tags ... and replacement backs for TV remotes
Now you've moved the printer into a whole new arena
Well done
Is the plastic a special UV safe type?
Regards
Guy
Offline frankenwing
« Reply #32 on: September 12, 2016, 10:56:10 AM »
I have a print area of 6x6x6" (15.24cm).
yeah I've used the printer to make a few bits and pieces on this and another bike of mine already. It is a major money saver when you can make your own plastic parts! And fortunately I've been doing 3D modeling for about a decade. I even replicated a quad-lock mount for one of the bikes to work with my quad-lock case on my iphone. Very handy 👍🏼
Probably not. I believe its just a standard PLA filament. But I always spray a number of coats of sand-able primer, smooth it down, then paint it.
Just printed it last night, only thing left to print is the bottoms of the fuel/temp gauges' casing.
Also managed to get all the wiring and electronics settled in on saturday. Biggest thing left to do is repair the dents in the gas tank and repaint it.
[ONE-OFFS]
Offline Quiltzig
  • K Guy
« Reply #33 on: September 12, 2016, 06:50:30 PM »
Are you going to paint the crank cover too?
Why remove the black coating from the fuel rail--black radiates heat better than anything and you want your fuel cool...?
That was the worst greasy motor top that i've ever seen--how could it get that bad.
They get that way on top of the motor if the breather hose is split or cracked. Very common on these older motors as they are around 20 years old now.
  • Hamilton - New Zealand
  • K75S
1987 K75S - cafe racer project
2016 R9T (wifes ride)
2004 K1200RS
Offline Scud
« Reply #34 on: September 12, 2016, 08:04:01 PM »
That is great work. I'm getting re-energized to get back into my project. Getting ready to powdercoat my wheels and intend to do the frame. I like the idea of using the same color on wheels and frame.
Yours will be so cool with white body on the black and gold mechanicals.
  • Carlsbad, CA
Offline herseyb
« Reply #35 on: September 13, 2016, 12:47:26 PM »
Well color me green over the 3d printer!  My dad has a laser cutter - maybe I can convince him to get a 3d printer too...
  • Brooklyn
  • '93 K1100RS
Offline frankenwing
« Reply #36 on: September 13, 2016, 01:30:00 PM »
It's worth the $. It helps being able to model 3D objects well too though. 3D printer software usually runs pretty terrible, so you'll want to make sure you can build a solid model.
I was able to test the fitment last night and the gauges, ignition, and switches fit really well. It was a bit too tight though, and one area didn't print correctly. So I'm going to fix it and modify the openings slightly and reprint again tonight.
[ONE-OFFS]
Offline frankenwing
« Reply #37 on: September 16, 2016, 11:35:57 AM »
A white tank and finished 3D printed dash. Have yet to smooth out and paint the print. But I'm not crazy about how it looks, or where itll sit. I may have some rethinking to do on it.
[ONE-OFFS]
Offline jaxon
« Reply #38 on: September 16, 2016, 12:15:10 PM »
"Gauge Sweetness"
They look really nice.
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
Offline Elipten
« Reply #39 on: September 16, 2016, 11:29:51 PM »
That is so cool.
  • San Antonio, TX
  • 1990 K75RT
« Reply #40 on: September 17, 2016, 06:59:45 AM »
That is so cool.
+1 on the gauge coolness factor.
Offline frankenwing
« Reply #41 on: September 21, 2016, 11:49:01 AM »
Reshaped the cowl.
[ONE-OFFS]
Offline frankenwing
« Reply #42 on: September 21, 2016, 11:59:45 AM »
[ONE-OFFS]
Offline herseyb
« Reply #43 on: September 21, 2016, 02:17:53 PM »
Hm... I like this, but I feel like the bright white takes away some of the visibility of the gold frame.
If that isn't the intent... perhaps some gold pinstripes would make it pop?
Beautiful job overall, no criticism intended.
  • Brooklyn
  • '93 K1100RS
Offline frankenwing
« Reply #44 on: September 21, 2016, 02:25:10 PM »
For me its the seat thats ruining it. Which is fine, that's just what came with the bike and I'm having a custom one made for it. But I went over some color options and I really couldn't find anything i liked more than white against the gold. I'm really liking the color combination.
[ONE-OFFS]
« Reply #45 on: September 21, 2016, 02:28:19 PM »
I agree about the seat, it looks a swollen and way too big for the bike. I look forward to seeing the custom one you are getting.  Nice work so far it is looking great  :clap:
Offline herseyb
« Reply #46 on: September 21, 2016, 02:48:30 PM »
Excellent choice then!
  • Brooklyn
  • '93 K1100RS
Offline TrueAce
« Reply #47 on: September 22, 2016, 12:52:32 AM »
Like what you've you done; tank holes needs to meet Mr. Dremel
  • Florida
Offline frankenwing
« Reply #48 on: September 22, 2016, 12:59:24 AM »
Like what you've you done; tank holes needs to meet Mr. Drexel.
Thanks. Actually putting the radiator shrouds on. Ordered a set off a guy from here.
[ONE-OFFS]
Offline frankenwing
« Reply #49 on: September 22, 2016, 01:02:25 AM »
Managed to fire it up and ride it tonight!
[ONE-OFFS]
