Author Topic: Need help mating Ducati switchgear to the K100 Harness  (Read 20521 times)
Re: Need help mating Ducati switchgear to the K100 Harness
« Reply #25 on: August 22, 2016, 12:34:49 AM »
Pick your running light power off of Green/Red available on the optional alarm connector in the relay box.
Offline Mike Flores
« Reply #26 on: August 22, 2016, 12:39:34 AM »
I cut out the alarm connector as well in the interest of "simplifying" things. Is it worth it to go back and repair that circuit though?
I suppose maybe I run the risk of pulling too much load through the green/black wire by having everything connected to/through it?
  • Los Angeles, CA
  • 1987 K100
« Reply #27 on: August 22, 2016, 12:32:53 PM »
Oooooooo :yikes:
Maybe it's time to add a relay-driven fuse block to the bike to allow for applications like this. Like with my TGPI board, I build these as well.
Offline Mike Flores
« Reply #28 on: August 23, 2016, 09:38:11 PM »
Got everything wired up, and I'm happy to report it all works as it should. Thank you for all your help rbm!!!
  • Los Angeles, CA
  • 1987 K100
