Author Topic: Whats this nipple?  (Read 7281 times)
Offline frankenwing
  • Bolted • Brewed • Originals ☠ ☕ 🏍
Whats this nipple?
« on: August 11, 2016, 06:12:01 PM »
Just bought this old k75 a couple weeks ago. Been restoring it inch-by-inch and I've come across a bunch of mystery things; wiring connectors that don't go anywhere, missing hose lines, etc.
I've checked the manual have searched over and over, but I can't find out exactly what this nipple is for, or where it should be routed. I'm guessing its just a vent, and thinking of putting a line on it to just run out underneath the bike.
[ONE-OFFS]
1976 GL1000 Bobber // 1987 K75
Re: Whats this nipple?
« Reply #1 on: August 11, 2016, 06:42:35 PM »
Just cap it off.  It used to vent the crankcase to the airbox (I think) but caused all sorts of starting problems.  Mine's been capped since it's first service.
Offline frankenwing
« Reply #2 on: August 11, 2016, 06:44:33 PM »
:2thumbup: Thanks!
[ONE-OFFS]
« Reply #3 on: August 11, 2016, 06:46:16 PM »
Fuel tank vent...........US only.
As Chaos says, just blind it........it was a service bulletin about that......as you could get fuel into
the crankcase if overfilling the tank.
Offline E30_Crazy
« Reply #4 on: August 14, 2016, 12:32:15 PM »
Weird, that one runs over to my throttles on my K100. Is this a normal difference, or possibly something the PO did?
  • Newport News, Virginia
  • '85 K100, '93 K1100RS
God created Crew Chiefs so Fighter Pilots could have heroes, too.
Offline frankenwing
« Reply #5 on: August 14, 2016, 01:11:02 PM »
Interesting. That explains the line coming from the gas tank. I was wondering if thats where it went since it fits, but i also thought it was odd to run overflow/vent to the case.
 :2thumbup:
[ONE-OFFS]
« Reply #6 on: August 22, 2016, 02:55:12 AM »
Speaking of nipples -- which everyone loves to do -- what's this? If fell on the ground while I was disconnecting something to lift the frame off the engine. Kinda looks like that other nipple except that one's sticking out of the engine.
« Reply #7 on: August 22, 2016, 03:26:25 AM »
A one way valve, is used inline on the above mentioned tank vent system.
Offline TX brick
« Reply #8 on: August 22, 2016, 06:56:07 AM »
Hang on to it. It will work as a one way valve for brake bleeding.
Ron
91 K75RT
Belton Tx
« Reply #9 on: August 22, 2016, 07:50:59 AM »
 :2thumbup:
Part of the EPA rules only here in the states, same rules that required the CAT converter in the exhaust.
Your car/truck has the same thing(if it's new enough, and gas only), engine draws the 'vapors' from the fuel tank when running. Newer computer systems on todays cars/trucks even measure this vacuum and will give you a check engine light if it can't meet a specific threshold.(and some wonder why the CE light comes on when the don't get the gas cap tight..... :2thumbup:)
