Author Topic: battery issues  (Read 2730 times)
Offline Oehmig
battery issues
« on: July 20, 2016, 10:19:06 AM »
Hey forum. So I'm helping a friend get an 85' k100 running again. I've finally got the fuel system corrected and everything in functional shape but here's the problem I'm running into. The previous battery was low and continually fusing the contacts in the relay. Couple of whacks. Temporarily resolved. What I'm up against now is this... I put a fresh battery on and ran it for about five minutes. While running for a few minutes, the battery dies and the starter contacts get fused again. Is this symptomatic of a bad alternator? Seems like even with a fresh, known-good, battery, it runs for a while and then the battery dies and the starter contacts fuse again. I'm thinking alternator but don't want to pull it without some input... Thanks.
  • Chattanooga TN
  • 1987 K75
Offline kennybobby
  • Last of the True Southern Sweet Mullets and Squids
Re: battery issues
« Reply #1 on: July 20, 2016, 11:18:08 AM »
It could be alternator not charging, but to know for sure you need more data--measure the battery voltage while OFF, then while running at idle and at ~3k rpm.
Also does the red battery indicator light on the cluster stay on or go off, or comes back on right before the engine dies?  If it is on while revved above idle then the battery voltage exceeds the alternator output and is not being charged.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
Re: battery issues
« Reply #2 on: July 20, 2016, 11:55:32 AM »
In addition to checking into kennybobby's observations, have you cleaned and tightened the battery ground connection on the transmission and the frame grounds?
