Author Topic: K100 build- making it up as I go  (Read 105217 times)
Offline Boxermann
Re: K100 build- making it up as I go
« Reply #75 on: January 19, 2017, 02:47:30 AM »
Shiny! Exhaust looks great.
Looking forward to see how you solve the mounting plates and linkage for the rear sets. I'm planning to do the same thing.
  • K100 / '87, K75 / '87
Offline jc55
« Reply #76 on: January 20, 2017, 06:41:45 PM »
I'm putting the bike back together and wet sanded the too glossy frame repaint with ultrafine scotchbrite and it came out perfect.
Here's how the rearsets went today...
I ordered indexable rearsets from Dime City Cycles for $150. They are TOP NOTCH. Unbelievable machine work and attention to detail.
3 heim/spherical rod ends (1/4-28) $9 each from NAPA  (1/4" steel rod as well)
$12 worth of 1/2" aluminum, 6" wide
The first thing I did was machine down and thread the stock master cylinder rod to 1/4 -28 threads and bought jam nuts. This isn't an easy task.  I have lathe and mill access but did everything by hand.
With poster board templates that were pleasing to my eye anyways, I settled on a design.
Cut out the brackets, matched/shaped them to be exact twins, found a good rearset position, drilled for that, champhered all holes, tapped the rearset tab for 1/4-20 as a secondary safety, mounted the stock master cylinder with spacers I made, and most importantly I machined a stop block. This stop block is absolutely imperative to not pull the push rod out of the master cylinder and get yourself killed.
I didn't want my master pointing up in the air so I went with this layout. I need to swap out all of the fasteners for nylock, stainless, etc. and polish everything.
The shifter side is almost done and I'll used the stock muffler mount and weld it to my custom exhaust, then bolt to bracket. I may mill recesses for my bolts but kind of don't want to lose thickness of the brackets.
  • Carrollton, Ohio
  • '90 K100LT '77 Gl1000
Offline jc55
« Reply #77 on: January 22, 2017, 12:15:25 PM »
After about 5 hours of hand sanding, applying 3 coats of clear to the rear set brackets.
  • Carrollton, Ohio
Offline MaraudeRS
« Reply #78 on: January 22, 2017, 12:36:45 PM »
Sub'd. Awesome project, so far!
  • Monterey, CA
  • 1992 K100RS
Offline jc55
« Reply #79 on: January 23, 2017, 10:52:43 AM »
Thanks MarauderS!
Well, love 'em or hate 'em. Functioning rearsets for $200 total. Front and rear abs to non abs conversion done and bled.
Rear fill tubing will be battened down before launch. Mounting the m/c this way does create a possible issue in that that supply tube dorks itself towards the tight heel.
Wasn't planning on a rear brake light switch but if I want one later, I can add one later. Especially when I upgrade to stainless lines. Thanks for looking.
  • Carrollton, Ohio
Offline Markus77
« Reply #80 on: January 23, 2017, 12:59:05 PM »
That's awesome work! They look great and you certainly saved a bunch of $. Really looking forward to seeing this bike when it's done:)
  • Toronto
  • '94 K75RT
Offline jc55
« Reply #81 on: January 23, 2017, 01:03:52 PM »
Thanks man. If it looks half as good as yours, I'll be happy.
  • Carrollton, Ohio
Offline jc55
« Reply #82 on: January 24, 2017, 02:29:26 PM »
Today I cleaned up the cruddy sender and made up a new wiring harness for the in tank fuel pump. In the process I'll be replacing the sender o-ring and leak checking.
Wanted to check bike post ABS harness delete
I ALWAYS label  everything I disconnect. Apparently when I removed the starter, from the time I disconnected it until I grabbed the marker and tape, I labeled the battery positive terminal as, 'starter'. So after troubleshooting no power to ignition switch and coil of starter relay...I figured it out...doh!
Used a syringe to put fuel to the throttle body vacuum ports, and she fired right up and ran. Yay!
I need to test the fuel injectors using the fuel pump, then it's paint, body and custom wiring mods.
  • Carrollton, Ohio
Offline jc55
« Reply #83 on: January 26, 2017, 01:34:00 PM »
Yesterday I used RBM'S procedure to flip the fuel sender board and set it for 0-100 ohms.
Also bench tested and cleaned the injectors. After starting the bike on the new fuel pump.
The tail had a little 'hook' to it so I cut 1/2" off the back and re streamlined it. (Nerve wracking this late in the game)
I fabbed up a bolt on tail light and removable licence plate bracket. I really want to build a 'hugger' rear fender and mount the plate in front of the rear tire, but I'm not gonna complicate my life right now.
Made an articulating aluminum bracket for the acewell so that I can move it around.
Cut the fender down and modified it to mount lower over the front fender.
  • Carrollton, Ohio
Offline jc55
« Reply #84 on: January 28, 2017, 01:52:50 PM »
Mixing custom colors today...blah!!!
IU
I wanted Jeep 'anvil' blue gray but bike of the year is using that.  :falldown: don't want a safe color like black, white, silver, bare metal, etc.
I considered Subaru desert khaki, Chrysler's anvil, Toyota's concrete, but settled on 2013 dodge dart Laguna blue.
Well, that was a mistake. So here's 3 custom sprayouts using Laguna blue and a metallic secret blend. The second pic is ultra bold. The first pic on the tank is the one I'm leaning towards. It's more of a BMW Z3 style of blue gray metallic color.
Plus then no one can copy the color.
Opinions please!!!
  • Carrollton, Ohio
Offline Markus77
« Reply #85 on: January 28, 2017, 02:29:21 PM »
I like the second pic - but I'm sure they would all look good - tough decisions!
  • Toronto
  • '94 K75RT
« Reply #86 on: January 28, 2017, 02:39:14 PM »
Opinions please!!!
Thanks for asking. :giggles
The first panel—a color I'd call What You Lookin At Grey—has a certain five o'clock shadowness and penitentiary hue bound to create a stir among night-dwellers. The second—East Wing Blue—strikes me as hospital recovery room decor—not a particularly desirable association. The last I'd call Long View Arctic—the view from the cockpit before being catapulted from the deck of USS Carl Vinson over the Bering Sea. I like the chill.
Offline MaraudeRS
« Reply #87 on: January 28, 2017, 02:40:38 PM »
I like the color in the first one. I think the grayer blue would look sweet on your bike
  • Monterey, CA
  • 1992 K100RS
Offline jc55
« Reply #88 on: January 28, 2017, 02:59:42 PM »
Lol, Laitch. Spent quite a bit of time on carriers myself.
I really appreciate the opinions. I usually take the easy way out and this isn't easy for me.
Yes, the last one is super bold, almost something you'd see on a Subaru. I like it but it's a big commitment and I don't know if I have the guts.
The first one is a little classier. It will make the bike look more expensive and tasteful.
Thanks again! :2thumbup:
  • Carrollton, Ohio
« Reply #89 on: January 28, 2017, 03:05:37 PM »
First time I've seen the words bold and Subaru together. Old? Sure, especially up here where every other person has one, or parts of one.  :hehehe
Offline jc55
« Reply #90 on: January 28, 2017, 03:28:02 PM »
Have you ever seen a Subaru owner upset? It's like George Mcfly meets Bernie Sanders...very bold!!! :hehehe
  • Carrollton, Ohio
« Reply #91 on: January 28, 2017, 03:33:06 PM »
I've got my binoculars and that's now on my Life List right after I spot a Ruffled Tightarse.
Offline jc55
« Reply #92 on: January 28, 2017, 03:41:21 PM »
Hahaha
  • Carrollton, Ohio
Offline jc55
« Reply #93 on: February 04, 2017, 06:20:34 PM »
I know there's usually a big mystery behind paint and body generally, so I'll be documenting that. There are many ways of doing it, of course, but projects seem to disappear from the forum only to reappear completely painted and finished.
Panels must be clean! Here are some products I use below.
Filling holes in plastic and fiberglass, I drill out the hole one size to remove any paint, clean, then mix epoxy with SM fairing compound. The compound makes it thick and easy to sand. 24 hours to cure, and tape or plastic over holes to eliminate sag. I've had the best luck with this method in the past.
As much as I would like to do perfect metal work, I can't. I use USC All Metal for roughing in gaps, and welds. It's a catalyzed aluminum filler. Light media blast, then applied and sanded.
After roughing in the body work, D/A sand with 80 grit,  I cleaned, then everything gets a coat of epoxy primer. All panels must acclimate, along with the paint to follow the tech sheet. You can't bring a 50 degree panel into a 75 degree room and start painting. I use a temperature gun to make sure everything is up to temp.
 Filler first or second is a big argument, but I want my metal sealed first.
Everything will get a complete skim coat of body filler next.
  • Carrollton, Ohio
Offline Boxermann
« Reply #94 on: February 05, 2017, 03:28:20 AM »
Thank you!
Offline jc55
« Reply #95 on: February 05, 2017, 06:24:49 PM »
At the 24 hour or so mark, I used 150 grit to roughen up the epoxy primer. If I top coated it yesterday with high build primer in the recoat window, I wouldn't have had to do that. It's still debatable at 24 hours, but it gives it more 'bite'.
Fixed a couple of small imperfections on the tank and front fender, cleaned, tack clothed, then I shot 4 coats of high build primer. I will start the block sanding process later.
The tail and belly pan get an entire skim coat of filler after roughing up the epoxy primer with 150 grit. I used 80 grit initially on the filler, then was able to do most in 150 grit.
A little trick I learned is to start sanding before it has fully cured. It makes knocking it down so much faster.
The tail is 'roughed in' again. There is a canister of dry guide coat there on the belly pan. It's basically a black powder for guide coating low spots. Sooooooo much better than spray can guide coat imo.
I also found a project box and drilled for a grommet to enclose the neutral indicator board.
  • Carrollton, Ohio
Offline jc55
« Reply #96 on: February 06, 2017, 09:48:20 PM »
Still at it. 320 grit blocking on the fender, and scotchbrite to blend the edges.
Started with 220 grit on the tank.
  • Carrollton, Ohio
Offline jc55
« Reply #97 on: February 11, 2017, 09:28:22 PM »
Still in the land of block sanding. I forgot how much work this is.
Not doing this everyday requires extra steps that a pro would skip.
- several applications of filler and sanding with 150 grit on tail and belly pan
- epoxy primer again on tail, light blocking with 220 grit, 4 coats of high build primer on tail and belly pan, light glazing where needed, block sand with 320 grit, 4 more coats, 320 again, two more coats and final sanding before shooting.
Getting close, a couple of small spot glaze areas, then hopefully shoot color Tuesday. Looking for everything to flow, the flares on the tail pan are just too much work to get perfect.
  • Carrollton, Ohio
Offline BENSPEN
« Reply #98 on: February 11, 2017, 09:56:00 PM »
Jc55,
Build is looking really good, I don't know how you got the seat cowel looking soooo good, wish I had skills like that to complete the most daunting part of my project!
What are your plans for your brake light switch on your reassess? I was thinking about something similar but didn't know what to do with that.
Thanks! Looks fantastic!
-Ben
  • VT
  • 87 K100rs
Offline jc55
« Reply #99 on: February 11, 2017, 10:02:16 PM »
Thank you, Ben. The seat/tail is made out of 3 pieces...I have no idea how it turned out like it did either, lol.
I did some reading and decided to skip the rear brake light switch.
1) I can add a hydraulic line switch later
2) the front brake switch alone will suffice, I live in a super rural area
3) no rear brake light means I can scrub speed without police attention
  • Carrollton, Ohio
