Author Topic: Flasher switch  (Read 18996 times)
Offline White Dog
Re: Flasher switch
« Reply #25 on: April 01, 2016, 08:38:35 PM »
Fer godsake, Whitey. Is your Google broken?
Don't say I never gave you anything. This will work for your bike although it's a year earlier.
Hey Laitch, you gotta cut me some slack.  I'm a newbie to BMW.  Who would have thought the fuses would have been identified in the Riders Manual and not the wiring diagrams in the Clymer?  Anyway, I appreciate your help.  Guess I need a refresher course on reading and comprehension--particularly the new terms being tossed at me, i.e., perch, centre, etc, etc.  I want to ride but need to mend a few things before I do any serious riding.  I did grease the side and center stands last night, as the side stand was a bit sluggish, but not anymore.
When does your riding season crank up?
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Offline TrueAce
Re: Flasher switch
« Reply #26 on: April 01, 2016, 09:31:59 PM »
True story............I was actually asked recently by a "Snow Bird" from Minnisota , "Why do you need so many motorcycles when you can't ride but one at a time?"..................and I told him " why do you have so many golf clubs........one for every task". His visa is cancelled for next winter season Smart ass Yankee, Southern Man don't need......oh, we already did that one.
  • Florida
Re: Flasher switch
« Reply #27 on: April 01, 2016, 09:36:58 PM »
Hey Laitch, you gotta cut me some slack. . . .Who would have thought the fuses would have been identified in the Riders Manual and not the wiring diagrams in the Clymer?
Me, for one. Consider slack cut, for whatever that's worth, Whitey.
Riders are on the hard surface here already. Dirt bikes are starting to thump through the mud up here, too, but I'm biding my time, hiding my ride from residual salt—adjusting this, tweaking that, installing the other—but mostly bucking logs and splitting wood while the weather's cool and the black flies are dormant. Probably roll out mid-May and stay rolling as long as I can.
Offline TrueAce
Re: Flasher switch
« Reply #28 on: April 01, 2016, 09:49:43 PM »
Rooooooooooollllllllll Onnnnnnnnnnnnnnn! I am headed to NC this weekend to to do a Smokey Mountain Spring before heading West! See you in Montana, Laitchster! Or at least Colorado!
  • Florida
Re: Flasher switch
« Reply #29 on: April 02, 2016, 12:34:57 AM »
Snowman you just described Cricket.
Offline White Dog
Re: Flasher switch
« Reply #30 on: April 03, 2016, 10:26:07 AM »
Tested the hot wire to the flasher switch last night and voltage was good.  Pulled switch out of panel (unloosened the wire straps on the neck tube to provide some slack in the flasher wires), took switch apart and determined not all the parts are in that switch, so I ordered a new one this morning.  May never have to use the flashers (hope I don't) but I did check them and they function properly once the circuit is completed from the hot wire to the ground.  This is what the rocker switch is supposed to do.  This from the Department of Redundancy Department.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline TrueAce
Re: Flasher switch
« Reply #31 on: April 03, 2016, 01:23:42 PM »
Way to go, WD, that's the way to follow through......good job.
  • Florida
