Author Topic: New project, new donor help needed.  (Read 29027 times)
Offline PiotrK100
Re: New project, new donor help needed.
« Reply #25 on: April 30, 2016, 05:20:48 AM »
So, now my wheel is already mounted and all looks great, all I was needed is 2mm original additional shim. There is no much space between monolever and tire but are not touching and about 3mm space left. Will include pictures later on.
 Now on your request SJ 2000 please find pictures I've found regarding handlebar switches. Sory I could not found another pictures of existing handlebars switches. If you want that pics in high res send me your email.
  • Poland
Offline PiotrK100
« Reply #26 on: April 30, 2016, 05:28:44 AM »
Another question to ALL. Anyone try to mount fuel radiator? I had that idea in my previous project but somehow I drop it but now will definitely go for it!! Need some suggestions and YOUR opinion.
Why, just because and may be a little to decrease heat of my fuel in tank.
  • Poland
« Reply #27 on: April 30, 2016, 06:05:45 AM »
Since you do not have any fairings or shrouds on the front, mount it on the radiator near the top.  This will give it cool air flow with the motorcycle in motion, it will ensure that the amount of fuel line exposed to road debris is minimized and will be as visually unobtrusive as could be possible.  Use long tie wraps that goes through the fins to secure the fuel cooler to the radiator.
« Reply #28 on: April 30, 2016, 08:26:14 AM »
I put an extruded aluminum cooler on my K75 that looks pretty good.  No time to post details now.  Will post some links and photos this evening.
Offline PiotrK100
« Reply #29 on: May 01, 2016, 10:18:39 AM »
Fits perfect, works perfect!!!
  • Poland
« Reply #30 on: May 01, 2016, 10:45:07 AM »
what abouts when its hawt... what abouts flex when dragging toe... im betting a little friction...
Offline PiotrK100
« Reply #31 on: May 01, 2016, 11:10:33 AM »
The trace on monolever comming from previous mount without additional shim. In case I'll see any friction will just buy another 2 mm shimm and that will solve all. But so far so good. Will go for a ride soon so will see how it behaves.
  • Poland
Offline jjs1234
« Reply #32 on: May 02, 2016, 10:51:01 AM »
What are you planning to do with the front rim? Since it is different?
Also the LAST picture on the original OP post:
Was that taken off google? (Im looking to find a similar setup and muffler) Know where I can find one?
  • Northern California
  • 1984 K100
Mr. Creative
Offline PiotrK100
« Reply #33 on: May 02, 2016, 04:07:41 PM »
Well, front is intend to be from GSXR or R1. But did not choose yet. Forks up side down and all that stuff... bmp
  • Poland
Offline jjs1234
« Reply #34 on: May 02, 2016, 09:40:17 PM »
How extensive do the forks need to be modded to fit onto the frame?
I would like to see pictures of what you did to make it (forks) fit if you dont mind :)
I am having trouble with sourcing k1100 forks now (the guy hasn't got back to me) and I am looking at alternatives other than the k100...
Thanks!
  • 1984 K100
Mr. Creative
« Reply #35 on: May 03, 2016, 06:27:42 AM »
Offline PiotrK100
« Reply #36 on: May 03, 2016, 10:29:22 AM »
Well, I did not decide for 100% what will be on the front end but one option is Ninja full "set".
  • Poland
Offline jjs1234
« Reply #37 on: May 03, 2016, 11:07:38 AM »
is the rear rim bolt-on that matches the front?
Its going to look nice though!
  • 1984 K100
Mr. Creative
Offline sj2000
« Reply #38 on: May 04, 2016, 10:27:55 AM »
I already had a complete front end from Suzuki GSXR1000, don't have time to install it yet, if you are interested in Suzuki, then this diagram below will help you.
  • Parker, USA
