Author Topic: What are the bolts that attach the cylinder head to the engine?  (Read 15357 times)
Offline jjs1234
« on: February 19, 2016, 01:15:10 PM »
Max BMW states them as 11 12 1 464 069    SCREW - M10X135
I thought they were Hex Head but then I got confused that they might be Torx, or Allen? :dunno2:
Asking to see if I have the right tools for the job.
Thanks!
(Might do a k75 piston swap) :2thumbup:
Thanks!
  • Northern California
  • 1984 K100
Mr. Creative
Re: What are the bolts that attach the cylinder head to the engine?
« Reply #1 on: February 19, 2016, 02:04:53 PM »
JJS they are Allen bolts, and what is causing you to change the pistons.
Regards Martin
Offline jjs1234
« Reply #2 on: February 19, 2016, 02:25:50 PM »
because the k75 pistons are an upgrade with higher compression.
Its a worthy upgrade i'm told.
Ill end up doing a timing chain rebuild too. Guides and all.
  • 1984 K100
Mr. Creative
« Reply #3 on: February 19, 2016, 02:41:45 PM »
 :2thumbup:
« Reply #4 on: February 19, 2016, 02:54:30 PM »
On my k100 the cylinder head bolts had Torx heads on them.  I suspect they are the same on the K75 in order to handle the high torque they are tightened to.
« Reply #5 on: February 19, 2016, 03:02:29 PM »
Sorry I just looked at a parts fiche I should have checked further.
Regards Martin
Offline jjs1234
« Reply #6 on: February 19, 2016, 03:11:07 PM »
Torx then...
Okay thanks!
  • 1984 K100
Mr. Creative
Offline Bill
« Reply #7 on: February 19, 2016, 03:19:19 PM »
Seems to me you are going to short 1 piston  :yow
  • Sutton, Ontario, Canada
  • K100 LT
Current:  88 K100 LT
86 K100 R-?L?T parts collection in loose formation...
previous:
84 V45 Sabre
74 CB400
72 CB750
Offline jjs1234
« Reply #8 on: February 19, 2016, 03:45:58 PM »
buy 4 on motobins
  • 1984 K100
Mr. Creative
« Reply #9 on: February 19, 2016, 04:50:41 PM »
Thanks!
Couldn't you remove your valve cover to take a look at them yourself, jj, or did you do that but were unsure about what you were seeing? Hadn't you better do that anyway to verify?
  • 1995 K75 89,000 miles
Offline jjs1234
« Reply #10 on: February 19, 2016, 05:30:10 PM »
I was going to, I was placing an order for tools though.
  • 1984 K100
Mr. Creative
« Reply #11 on: February 20, 2016, 10:18:53 AM »
My bolts took a Torx T50.  I got mine at the NAPA store.  They have them in black for impact tools.  It was recommended to me to get the one with extended tip so you don't need to use an extension on your torque wrench.  Brace yourself, they ain't cheap.
You might also want to get a good breaker bar with a cheater.  Those guys are a bitch to break loose.  Mine took a 20" cheater.  And here's hoping you don't break any of them like I did.
Offline jjs1234
« Reply #12 on: February 20, 2016, 02:19:21 PM »
How do you end up taking them to the correct spec?
  • 1984 K100
Mr. Creative
« Reply #13 on: February 20, 2016, 04:42:50 PM »
It's hard to know what you're driving at with that question, jj, so I'm just going to supply this link and affirm that site as a handy place for information.
Maybe you could rephrase your question?
Offline jjs1234
« Reply #14 on: February 20, 2016, 05:12:30 PM »
Text to speech on this phone sucks.
My question was, how do you torque them to spec? I imagine to get the correct torque you would need a half inch drive?
  • 1984 K100
Mr. Creative
« Reply #15 on: February 20, 2016, 05:49:15 PM »
It's best to leave your imagination out of this, jj—right now anyway.
First, take the cover off and see what you've got.
Next, if you've got Torx heads, get the socket that Gryph recommended; then you may need to get an adaptor to fit both the socket and the torque wrench you're using. Which torque wrench type do you have—click, beam, digital, fandango or what? What size is its drive? You'll need to adapt one to the other if they're not the same size.
Offline jjs1234
« Reply #16 on: February 22, 2016, 10:53:07 AM »
Its a 3/8 drive twist handle (analog?).
I dont know what I was thinking, I got a T50 its 3/8.
Harbor freight sells a digital attachment torque wrench for a 1/2 in drive if I need that leverage.
  • 1984 K100
Mr. Creative
« Reply #17 on: February 22, 2016, 11:18:37 AM »
Once Martin reads your response I'm sure he'll step right up. Torque wrenches are among his many specialties.
« Reply #18 on: February 22, 2016, 12:06:48 PM »
Laitch I'm pleading the Fifth, can a Aussie plead the Fifth? :dunno
Regards Martin
« Reply #19 on: February 22, 2016, 12:08:49 PM »
Regards Martin
He can drink a fifth but it's more like 750ml.
« Reply #20 on: February 22, 2016, 05:45:20 PM »
Those cylinder head bolts need to get torqued to 36 ft-lb with an intermediate torque of 25 ft-lb.  Whatever size wrench goes that high will do the job.
Breaking those puppies loose is quite another thing.  Time, corrosion, heat/cool cycles and original assembly without anti-seize means you need to break at least twice that 36 ft-lb.  Use a 24" cheater and wear gloves because they snap pretty hard when they let go.
« Reply #21 on: February 22, 2016, 11:44:05 PM »
I was just over my mates place helping to resurrect a K75 RT. I thought I would check out the basis, for my saying that the cylinder head bolts were Allen bolts. He has a K75 engine without the valve cover, the head is held down by Allen bolts. I had scrounged some valve shims of it.  So could it possibly be an early one?? I've tried looking up part numbers and I can only find one number.
« Reply #22 on: February 23, 2016, 12:49:30 AM »
 A picture of an Allen headed head bolt. Has anybody else seen these.
Regards Martin'
« Reply #23 on: February 23, 2016, 11:02:16 AM »
2V models have allen bolts, 4V models have torx bolts.
« Reply #24 on: February 23, 2016, 12:44:20 PM »
Thanks Inge :2thumbup:
