Hello everyone!
I’ve been looking at the various oil leak threads, and wanted to post some images of my various leaks to get a bit of feedback before preemptively ordering some gaskets, RTV, o-rings, etc. Given the weather in NY, now is a good time to do a bit of work in the garage.
The bike has always had a bit of slow oil seep on the engine, but no actual dripping while parked until recently. During the summer I stored the bike in my brother’s garage for a few weeks on the center stand and noticed a small clear puddle of oil by/under the center stand. Smells like clean oil, not used motor oil.
I immediately checked the transmission oil and final drive oil, but both were at their proper levels. A leak, but also a slow one it seems. Based on the oily nature of my center stand and transmission bell housing area, I’m guessing that the gear oil usually just collects in the bell housing when I use the side stand for daily use and then straight down out the weep hole while I’m riding.
Based on what I’ve learned here
http://www.motobrick.com/index.php/topic,6933.msg47896.html#msg47896 I might go ahead and order the works (rear main seal, a new clutch O ring seal, a gear box input shaft seal, and clutch push rod rear seal) at least for that section of the bike. I figure I might as well buy them while they’re still around, and install them now while I’m in the mood. I think I should also take a look at the condition of the clutch boot next time I’m in the garage.
As for the leaks at the front of the engine, can anyone shed some light onto what I’m looking at. I haven’t found a diagram that is more informative than the parts fiche. Perhaps one or two leaks could be fixed with a cleanup and a fresh seal or gasket. I’ll post a selection of pics below. No drips, but a fair amount of seep.
I’m also planning to do my first look at the valve clearances, a spline lube, and whatever else I should do while the bike is apart. I bought the bike, a well cared for 1991 K75, at 32k miles and have put on a mostly trouble free 13k since. In the last two years I’ve done new spark plugs, air filter, fuel filter, fork oil, coolant, oil filter, and of course engine oil.
