Author Topic: Buying Used Brake Rotors ?  (Read 15037 times)
Re: Buying Used Brake Rotors ?
« Reply #25 on: May 04, 2016, 11:19:35 PM »
Could be, Scott. Part of the rotor surface felt raised to the touch, but it's so subtle.
« Reply #26 on: May 05, 2016, 04:24:59 AM »
the underpowered k75 is notorious for glazed rotors... the key is proper maintenance... it is recommend that you ride in a backwards motion give it full brakes while at speed... this maneuver will deglaze the rotors... and also realigns the relationship between the brake pads and the brake calipers...
« Reply #27 on: May 05, 2016, 10:46:16 AM »
...it is recommend that you ride in a backwards motion give it full brakes while at speed......
I find that when I do this I end up back where I started.
