Author Topic: Throttle body zip ties  (Read 3836 times)
DeanG
« on: August 13, 2015, 12:50:07 PM »
the mechanic who worked on my K75S before I purchased it used zip ties to seal the throttle bodies. I will check for leak. If so, could this be the cause of the annoying backfire I get?
Offline K75RT Keith
Re: Throttle body zip ties
« Reply #1 on: August 13, 2015, 01:34:46 PM »
Check the crankcase breather tube it's Z shaped near the airbox above the FPR back towards the transmission.  Could also be a improperly adjusted TPS.  Or, that you are not closing the throttle all the way on deceleration.
1990 K75RT
« Reply #2 on: August 13, 2015, 09:11:19 PM »
Backfire on deceleration? As I have heard/read about this on other K-bike forums, I'll just say that it is not uncommon.
I even get it on my 1100's.
1957 K1100LT 0302044 (R.I.P.)
DeanG
« Reply #3 on: August 14, 2015, 01:11:47 AM »
Thanks for the suggestions. I know that K bikes tend to backfire, but I don't want this one to. I will start testing for leaks and see if I can fix it. Stay tuned for the no doubt exciting results. The good thing about retirement is that you have time fool with stuff like this...
« Reply #4 on: August 14, 2015, 02:38:14 AM »
Check your TPS setting first.
When you drastically decelerate, make sure the throttle is 100% off otherwise you're still sending fuel to the combustion chamber which will cause backfiring.
You might need a new muffler gasket too.
