Author Topic: Replacing Pinion Oil Seal in K75 Final Drive  (Read 35787 times)
Re: Replacing Pinion Oil Seal in K75 Final Drive
« Reply #25 on: April 24, 2017, 09:36:34 PM »
In the event someone is lucky enough to stumble on this thread . . .
It doesn't take luck as much as it takes initiative. A Google search for K75 Pinion Oil Seal or k75 rear drive oil seal or k75 leaking rear drive put this thread at the top of the list.
All contributors have made this a useful thread.  :clap:
« Reply #26 on: April 25, 2017, 09:46:53 AM »
There are cheaper buy options if you google the part # -- why newegg the tech people would stock such a thing...strange.
I can't help wondering how you found this thing, jay1622. It's not something people stock locally anywhere.
Is the seal in question the one that prevents gear oil from seeping into the cavity in the housing where the gear splines are?
Offline jay1622
« Reply #27 on: May 11, 2017, 09:37:17 PM »
Apologies... I was going over some old notes and saw this; realizing it's gone unanswered. Strange indeed that Newegg would list it. The seal does, in fact, do as you mentioned. Equally important is properly prepped and applied Hylomar. I must have cleaned the threaded ring threads on the inside of the FD a dozen times before I stopped getting old residual oil, grease and guck on my rag. Same thing with the outer threads of the threaded ring, though that was much easier to clean.
  • Charlotte
Offline K75Slark
  • Das Fliegen Ziegel!
« Reply #28 on: July 31, 2017, 02:02:22 PM »
Slipring, is there any chance you would download your photos and repost them on imgur or the like in a gallery? I need to do this to my K75 and want to make your jig.
Thanks!
'92 K75-Midnight Blue-~76k
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #29 on: August 01, 2017, 10:00:12 PM »
Slark.........Review this post....
http://www.motobrick.com/index.php/topic,7029.msg48438.html#msg48438
here's the missing picture from his post.  IIRC it was the only "document" but there were a few pics of the finished product...  I made one and it works great...really solid and a HEFTY vise would be a massive benefit to hold all that stuff whilst twisting away with breaker bars and torque wrenches...
  • Austin, TX
Offline K75Slark
« Reply #30 on: August 02, 2017, 08:28:50 AM »
Thanks, Ape. I appreciate the repost.
