Author Topic: Wrench size for larger steering head lock nut on '92 K75?  (Read 6938 times)
Offline TaosBrick
  • RedHotMotoBricker
« on: May 06, 2015, 01:32:18 PM »
Yup, got me some play on th' steering head, alrighty. This kinda ch!t always happens when on the road, hundreds or even thousands of miles away from yer shop, right?
  Anyhey, what size wrench do I need for that big nut on top of the upper brace? I wanna get me to the nearest NAPA or wherever, buy a wrench and Deal With This Thing.
- Samurai Maxim
Offline TaosBob101
Re: Wrench size for larger steering head lock nut on '92 K75?
« Reply #1 on: May 06, 2015, 03:09:23 PM »
 Is it in this pdf ??????????????
http://www.motobrick.com/index.php/topic,2252.0.html
Section 32 steering over in the card file Johnny re-did
  • Jefferson County, Colorado
  • 1995 K75S
1995 K75S
Offline TaosBrick
  • RedHotMotoBricker
« Reply #2 on: May 06, 2015, 03:42:17 PM »
Problem solved. Friendly neighborhood Auto Zone guy mic-ed it, 32mm, we tightened it up, no mo slop. Yay!
- Samurai Maxim
Offline TaosBob101
« Reply #3 on: May 06, 2015, 04:01:10 PM »
  Now I know what size.......
  • 1995 K75S
1995 K75S
« Reply #4 on: May 06, 2015, 04:32:25 PM »
itsa 32mm..
« Reply #5 on: May 06, 2015, 04:37:34 PM »
the 1st thing i would do is replace the fuel filter... reset the 4pin under tank fuel pump connector... reset the jetronic connector...
see how it goes...
Offline TaosBrick
  • RedHotMotoBricker
« Reply #6 on: May 06, 2015, 04:45:52 PM »
Fuel filter replaced, no change in symptoms - that were on my other post ;-)
- Samurai Maxim
« Reply #7 on: May 06, 2015, 05:41:40 PM »
some will say leaking rubber hoses... some will say whack valves...
this same thing happened to me on the eleven hundert motobrick a ways back... it was the throttle positioning sensor adjustment...
