Author Topic: Speed sender wire?  (Read 3073 times)
Offline vesku
Speed sender wire?
« on: February 22, 2015, 07:34:59 AM »
Hi all. After swapping my driveshaft I noticed the wire from the speed sender unit is pretty badly damaged due to excessive heat caused by the scratching in the driveshaft casing. Can I replace the wire with any ole length of wire hanging around? Or is it something special? Or maybe somebody has a known good sender fs? TIA,
V
Re: Speed sender wire?
« Reply #1 on: February 22, 2015, 08:03:42 AM »
what moto... gotts a photo to post...
if its the wire that goes into the top of the final drive near the shock... i thinks its special and need to go oem on the whole shebang...  i had one getts rubbed open... soldered it back together and it didnt work... was told its some kinda special resistance wire... replaced the whole shebang and all was well...
Offline vesku
« Reply #2 on: February 22, 2015, 08:10:20 AM »
Yes, that's the one. K100RS -85. Dang, but luckily found already one off fleabay for under 50 Euros shipped. Thanks!
