About the fuel tank connector, green is power to the fuel pump, white is signal for the low level warning lamp,
yellow is for the gauge (if fitted) and the brown is ground.
About the FI relay, in the front right corner of the relay box you have four relays if you have ABS brakes.
The front left of these four is the FI relay, if you don't have ABS the rear left socket is empty.
