Author Topic: Engine noise  (Read 4752 times)
Offline dfx
Engine noise
« on: February 01, 2015, 12:59:50 PM »
;Hi folks, I wondered if anyone has anything on diagnosing engine noises. Mine is a kind of growling at very low revs (under 1000) when the alternator light starts to come on. I was wondering if it was big ends or the cam chain. The bike has done at least 120k km
  • Alsace, France
  • K100RT 1986
Re: Engine noise
« Reply #1 on: February 01, 2015, 01:20:44 PM »
Alternator bearings?  I had a similar problem with my K75RT.  Just a little roughness when the rotor was spun.
Offline Kyle10
Re: Engine noise
« Reply #2 on: February 03, 2015, 02:52:33 PM »
Mine had the same issue, if you mean a rattle/growl at low revs which disappears at higher revs.
The problem was with the backlash eliminator spring on the output shaft. I'm not sure that's the proper name for it, but its function is to ensure quiet engagement b. the gears. The part is cheap and it's a snap to install. It's just getting to the cursed thing, followed by the ordeal of reassembly. Replace the rubber dogs while you're in there, too.
If this is indeed the problem w/your bike and you take this route you'll be floored by the quietness/smoothness that results.
1985 K100rt
1983 Honda VF750F
The other 2% made it home.
