Author Topic: Boiling Gas  (Read 18758 times)
Offline bizzaro
  • co pilot
Re: Boiling Gas
« Reply #25 on: March 30, 2018, 03:21:40 PM »
I am doing the blankets and manual fan switches on my two K's this winter to keep the tanks cooler.  Looking at the fuel system plumbing on my 100 I wonder why I can't run the fuel pump output to the front of the rail and connect the return line with the fuel pressure regulator to the back end.
Putting the regulator outside the fairings should get it away from most of the engine heat.  Can anyone think of a reason NOT to do the switch?  Seems to me the rail doesn't care which end it's fed from.  Looks like it will make the hose routing a bit neater as well.
:dunno2:   I may just try relocating the FPR....................someday!  :giggles
  • Vermont
See Ya in the Twisties,
 Bizz
Offline Andy FitzGibbon
Re: Boiling Gas
« Reply #26 on: April 04, 2018, 12:02:55 PM »
I've had my gas boil on hot days. Did not seem to effect how the engine ran, but it did cause the fuel pump to blow fuses pretty consistently.
Andy
  • Montrose, WV
