Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3597905 times)
Offline CRASH
« Reply #450 on: June 29, 2012, 06:43:02 PM »
.nomartirechanger.com/products/1]http://www.nomartirechanger.com/products/1[/url]
This is the one I got. Yes it's manual, but it works ok for me, better than just irons/spoons.
Found a used one on C.L. in Florida for $200
That is a smokin deal.  I have a "Cycle Hill" ... the non industrial version of the NO MAR, but way better than I have seen in most shops. Cost almost 3 times what you paid for that No Mar ...  :2thumbup:  Makes changing tires a party!
- CRASH -
« Reply #451 on: June 29, 2012, 10:27:38 PM »
How Not To Install an Oil Level Viewing Glass
I've had a new oil level indicator sight glass sitting on the shelf for 10 months but I always forget to install it at oil changes. The sight glass on the bike is nearly impossible to see through. I realized last night that if the bike was on the side stand the glass can be changed without draining the oil. Doh!
I decided on the screw method (not the soldering iron method) to remove the old glass (which is actually plastic) and the old sight glass came out without much of a fight. A screwdriver, sheetrock screw, and some needle-nose pliers did the trick.
I cleaned the aluminum mounting surface and the rubber ring around the glass with an oily rag, and proceeded to push the new sight glass into place. Then it occurred to me that both surfaces should probably be clean and mostly free from oil residue so I wiped them down with a clean cloth.
It took a few tries to get the new sight glass in place evenly with my fingers, about halfway installed. The largest socket I have is a 1-1/8 and that, along with a rubber mallet finished the job, but I had to hit the socket a little harder than I though necessary to seat the rubber seal. I fired up the bike, let it get hot enough for the fan to kick in for a while, and it all looked great.
Today I started thinking that maybe the mounting surface and rubber seal should be ultra-dry and clean, and a little internet reading seemed to substantiate that. I also stumbled onto some threads where different rider's sight glasses had fallen out while the bike was in use, and some had reported seeing the glass get "cloudy" just before. I imagined how tragic it would be to have it pop out on the highway at 70mph, with oil gushing under the rear wheel.
So this afternoon I fired up the bike again, let it get a little warm, and noticed an odd fogging in the sight glass. I didn't look like frothy oil, but more like stationary vertical cloud streaks on the inside glass surface with clean brown oil behind them. Had I broken the glass under the rubber seal when hammering it in? Was it not seated enough? I'm not taking any chances.
The new level indicator is actually made of glass so the soldering iron method will not work to remove it, and the screw method has the potential to leave shards of glass in the oil pan. The only way I could figure to remove it safely was to drain the oil, pull the oil filter, and tap the viewing glass from inside the oil pan with a long screwdriver. That worked.
Tomorrow I'll pickup a new sight glass / level indicator (and a spare) at the dealer and finish the job properly. I'll stop by the hardware store and get a short piece of 1.25" PVC or a wood dowel (a better fit than my 1-1/8 socket) to help tap it into place too. And I'll thoroughly clean all surfaces.
Moral of the story: Measure twice, cut once. Do your research first.
« Reply #452 on: June 29, 2012, 10:50:32 PM »
Make sure to install it right side up...
Offline sh00ter
« Reply #453 on: June 30, 2012, 11:50:16 PM »
Rebuilt the seal on the oil sump and the water/oil pump.   Buffed off the rust and reused (GASP) the impeller, bolt, seals (didn't pull the shaft) and o-rings.   Tomorrow we'll know if she leaks :)   Used Permatex Ultra Black for the sealing.
Apparently my leak was coming from the top of the oil pump - the half moon pressure relief slot was partially plugged as was the relief in the casting of the pump.
Here they are all spiffed up.   There was a bit of rust on the impeller and the bolt; I'd guess from the times in her life where she sat for an extended period of time.
'94 1100 RS
Offline sh00ter
« Reply #454 on: July 01, 2012, 05:43:00 PM »
Success! The old girl is dry as a bone.
'94 1100 RS
Offline roninvt
  • free range, cage free
« Reply #455 on: July 02, 2012, 05:25:03 PM »
Changed my oil and filter and replaced my front and rear brake pads today.  Then filled up with ethanol-free high test.  My bike is very happy :bmwsmile
1990 K75C
1993 K1100RS
Offline sh00ter
« Reply #456 on: July 04, 2012, 02:08:43 PM »
Today was the day I installed my new Upgraded injectors!  heres the before and afters.
Replaced injectors with a 4 Hole spray Injector for better flow
Also replaced all the fuel lines while I was down there.
The injectors sound a little different to, you can actually here them running if you pay attention to them.
More Humming for the brick!
** Ran a good 5-10 Miles on them. Definetly alittle more throttle response and torque! No more Stuttering as you decrease RPM's either. A Lot more reponse for the buck I'd say. Original OEM Injectors never serviced and bike is at 33K Miles now.**
Starting to feel like new again!
Are these the injectors?
fleabay injectors
'94 1100 RS
« Reply #457 on: July 04, 2012, 03:27:05 PM »
Changed the air filter.
Could never figure out how to get the air filter out of the box since the top only lifts about .5cm.
"WTF kind of design is that?" I said to myself on previous attempts.
Read a forum thread that mentioned in passing that the filter IS PART OF THE BOX (not IN the box) and it simply slides out. Well, hot damn.  :hehehe
Offline BillyMac
« Reply #458 on: July 04, 2012, 06:59:34 PM »
Finally changed out the spark plugs that I've been procrastinating on, added some engine restore, a little techron concentrate, fixed my fork oil drain plug problem.
Time to enjoy the rest of the 4th riding around  :tongue
1990 BMW K75 - Current
1967 Yamaha YCS1 Bonanza 180
Offline branandfox
  • Loraine. K1050RS
« Reply #459 on: July 06, 2012, 03:58:46 PM »
Yeah shooter, that be them! Duck actually just installed some as-well so if you want a second opinion of them then hes got it! more torque, Maybe a little bit of a smoother engine, and Better MPG! Its a Great upgrade!
Ducks Review Below.
Butt Dyno definitely approves.  :2thumbup: When I went from a 32:10 K75 monolever to a 32:11 paralever final drive it seemed a little luggish in low RPMs in first.  That's pretty much gone now and it seems to have better torque through the whole range.  As for smoothness, that's pretty hard to tell since the K75 is so smooth in the first place.
Five Motobirds!
 :mbird :mbird :mbird :mbird :mbird
     PS! Im not sure the difference in the K1100 and K100 Versions of the bosch injectors, If you have a K100 there are K100 plug and play models by Osidetiger somewhere floating around. Just make sure they are compatible!  :hmm:
Oh did I mention they are sexy aswell? Because they are!
Hit the throttle and live.
Don't blink.
Don't slow.
Just breathe.
Offline sh00ter
« Reply #460 on: July 07, 2012, 10:42:12 PM »
Ducks Review Below.
Five Motobirds!
Sold! Gonna get me a set too.   I gotta replace some hoses in there, figure I may as well throw a performance "fun" upgrade in there while I'm at it  :)
'94 1100 RS
Offline branandfox
  • Loraine. K1050RS
« Reply #461 on: July 08, 2012, 04:18:56 AM »
That's what I did, Replaced all the fuel lines while I was doing there fiddling. Beemerboneyard.com has a good 5 foot of line for sale, you can use the code "bmwmoa" for 10% off aswell!
Don't blink.
Don't slow.
Just breathe.
Offline branandfox
  • Loraine. K1050RS
« Reply #462 on: July 09, 2012, 07:00:43 PM »
 So who else hates they're BMW stock K100/K1100 mirrors? I'm sure I'm not the only one. When I got my baby she had a rattling left mirror and a right casing that would come loose from the mount. The right blinker wasn't connected and needed rewiring, and both casings were damaged and beaten up. So on a little ride the day before I got to get my new pirelli tire put on, after spending a good 2-3 hours putting in those new injectors I have been raving about, I hit a little bump in the road and the damn right casing and mirror came all the way off and fell into Busy rush hour traffic  On a 4 lane highway. I walked up and grabbed the casing to notice the mirror, which was cracked slightly on the left corner before, Had fallen off somewhere and broken. All that was left intact was the busted up casing. I'm sure the dealer got a good kick out of me riding with one mirror and busted up casings! meanwhile the whole ride there I was spewing many a "praising" remark about these damn mirrors. Im sure my helmet really appreciated all of that being thrown around inside of it! After returning with the new pirelli Installed I decided to look for an alternative to my mirrors. My buddy has a katana with some aftermarket bolt ons that were made specifically for the katana, Which I liked alot. So I went over my bike and found a mounting point and sure enough found a good place. Ordered my Katana bolt ons and installed them this morning. the funniest part? I had nessy parked by the front door this morning and when UPS delivered my mirrors the guy knocked off the right casing. I thought he was about to cry, I couldn't help but laugh. Here is the before and afters of the install. I will be looking for a alternative blinker source next. Hopefully I can find some nice flush mount ones I can install where the old mirrors used to be! these new mirrors sure hold well and make the bike look a lot more sporty!
Don't blink.
Don't slow.
Just breathe.
« Reply #463 on: July 09, 2012, 07:04:09 PM »
Stainless steel fishing leader "leash" so they don't fall to the ground and will stay with you if they come off at speed:
Offline branandfox
  • Loraine. K1050RS
« Reply #464 on: July 09, 2012, 07:14:07 PM »
haha good idea for those who like the mirrors but I am now pretty fond of my bolt ons!  :2thumbup: for the clever fishing line trick though!
Don't blink.
Don't slow.
Just breathe.
Offline tsbt
« Reply #465 on: July 12, 2012, 09:45:24 AM »
And if you're ever camping near a creek and need a spare! What pound line is that?!
92 K100RS 4V
75 KE125
« Reply #466 on: July 12, 2012, 09:48:40 AM »
30
If you're using a 30# leader to fish in a creek then you're doing it wrong. :loco:
« Reply #467 on: July 15, 2012, 11:38:12 AM »
Adjusted my clutch so it engages about halfway to the handlebar.  It had been engaging about half inch in and drove me nuts, but as soon as I'd get off the bike my brain forgot to take 5 minutes and fix the stupid thing, until I backed down the drive and took off the next day.  :lol: :loco:
« Reply #468 on: July 15, 2012, 06:05:45 PM »
the brick of the corn is in hibernation ...
In July??
« Reply #469 on: July 15, 2012, 08:32:37 PM »
That's his vacation bike not the one he hauls around the rest of the year.
Offline CRASH
« Reply #470 on: July 15, 2012, 08:54:22 PM »
So I keep looking at this picture, you need to explain the "shell" of your mirror and show some other angles.
- CRASH -
« Reply #471 on: July 15, 2012, 09:08:12 PM »
Offline sh00ter
« Reply #472 on: July 17, 2012, 04:13:29 PM »
It was a hot one -- man this was no fun.  However the "butt" test after all this work yielded pulling the front end up off the ground twice for the first time ... so I guess it worked :)
replaced breather hose (responsible for oil leak; it was nearly severed at the block)
new rebuilt 4 hole injectors
cleaned and re-gapped spark plugs (2 were a little foul)
sync'd throttle bodies
Unrelated added a "new" way to connect the cruise control - straighter pull and a smoother, quicker engagement (ymmv)
'94 1100 RS
« Reply #473 on: July 19, 2012, 09:23:49 PM »
This afternoon I installed a cruise control with a windscreen switch for CDB and then synch'd his TBs.
Offline Crapdealerbob
« Reply #474 on: July 19, 2012, 09:39:39 PM »
Thanks again Duck, see you Sunday evening !!
Crapdealerbob
Wickenburg, AZ
1991 K100 RS
