Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3594297 times)
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #2850 on: July 15, 2017, 05:16:05 PM »
Blitzen, a few years back I bought rattle can paint from these folks.........
http://www.66autocolor.com/Motorcycle-Paint-BMW-Blue-p/bmw-blue.htm
Not perfect.. the metallic "flake" in the paint wasn't "quite" the same size as original, if that makes any sense....but the actual color was shoot howdy close for Mystic Red....kinda pricey for rattle can, but not bad at all if total  respray is out of the question....
  • Austin, TX
« Reply #2851 on: July 15, 2017, 06:01:30 PM »
Chaos be aware that your side covers on the K75s are held in place by the edge of your fuel tank. If the pins are loose in the rubbers, the omission of the "C" clips can result in the rear of the tank jumping up and the side covers falling off. A mate used to loose his, and it wasn't until had him drive over speed bumps at a local supermarket and the covers eventually fell off that he believed me. It doesn't happen on every bump or big pothole, the stars just have to align, and bingo they make a bid for freedom. With side covers getting dearer and harder to get, you have to weigh things up,conflagration or financial loss. :nono :dunno :hehehe
Offline MIbrick
« Reply #2852 on: July 15, 2017, 06:04:19 PM »
Well, first I got my hair cut. Then I went by the only pure-gas place around. Which is when I put a bottle of Techron Complete Fuel System Conditioner in the tank.  Then I proceeded to rip off about 120 miles of alternating yeeha and WTF (as in, "WTF is the problem with these people driving seven miles over the speed limit? And why didn't the State put any passing lanes in this God-forsaken highway?!")
https://a.rever.co/rides/571719
I'm hoping the Techron does...something.  Unrelated note, what's the general consensus on fuel tank rear post c-clips?  I know Chris Harris says you'll die for sure if you leave them on, but maybe there's a reason BMW design them to be there?
  • Michigan
  • 1986 K100RS (ohne Tragkorb)
« Reply #2853 on: July 15, 2017, 06:20:56 PM »
MIbrick read the previous post. The side covers on the K75s are held in place by the back edge of the fuel tank. If you omit the "C" clips there is a possibility that on hitting a speed bump or large pothole the tank can jump up releasing the side covers. This will not happen every time you hit a bump, as with all things there are variables. How much fuel in the tank, how tight are the tank pins in the rubbers, how hard you hit the bump. The other model Bricks vary in the way the side covers are attached. And I don't know what other Bricks rely on the edge of the tank for security. As to what else can happen by not securing the tank I'm not sure, I just know that I don't need the hassle or expense of loosing mine.
Offline MIbrick
« Reply #2854 on: July 15, 2017, 06:45:27 PM »
Hi, Martin-
The board warned me there was a new post I should read before hitting post on mine, but I ignored it. I was just thinking that I have a serious distrust of the sight tube on my coolant overflow and wanted to pull the tank back to get at the coolant fill just to see where the level is at in there. But, man, those c-clips are a PITA. I'm inclined to leave my c-clips on, though I have a K100 with low-seat and, thus, no side panels any longer.[/size]
  • Michigan
« Reply #2855 on: July 15, 2017, 07:07:44 PM »
MIbrick cool , I have a bit of bent wire velcroed under my seat for the express purpose of removing the "C" clips and it also removes the little clips on the seat pins. Another inmate has put skinny cable ties around his "C" clips which allows him to easily remove the clips.
« Reply #2856 on: July 15, 2017, 08:00:03 PM »
What is there to distrust about the coolant level tube? Is it opaque? If you can see the marks on it, if you can see that the coolant level is between the marks and you know the tube isn't kinked along its length, trust it.
Offline MIbrick
« Reply #2857 on: July 15, 2017, 08:44:49 PM »
Bottom half is opaque, top half is blue. I can see the coolant level in it (sorta, but yeah) and it's about 2/3 of the way to the MAX line. But, I just replaced a shit ton (or metric shitte tonne, for our Canadian contingent) of hoses and gaskets and o-rings and well, Laitch, you see, I suffer from this weird anxiety that I did something wrong and my cycle is going to kill me as revenge.
  • Michigan
« Reply #2858 on: July 15, 2017, 08:49:56 PM »
Back to the minivan with you, MIbrick. Don't forget to buckle up. :giggles
Offline MIbrick
« Reply #2859 on: July 15, 2017, 09:09:59 PM »
Request denied.  I actually have become quite attached to the bike, maybe due in no small part to the amount of time wrenching on her to replace all that stuff. ;)  I put on 120 miles some of it at an extended 85 mph (90 indicated, something else that bothers me). I'm pretty sure if there were a coolant issue it would have surfaced somewhere in that 2.5 hour trek. But...
  • Michigan
Offline MIbrick
« Reply #2860 on: July 17, 2017, 10:15:03 PM »
Today I noticed that I had installed my crankcase breather tube upside down. That's what I get for putting it on before the air box was back in place, I guess. It took all of a minute to remove it, dropping one of the clamps down behind the FPR in the process. It took the better part of 20 minutes dicking around to get said clamp back. Under a minute to get the hose reinstalled. Then I went for a 55 mile ride just to make sure everything still works. It does.
  • Michigan
Offline BlitzenGruv
« Reply #2861 on: July 21, 2017, 10:27:00 AM »
Changed the oil last weekend. Not much mileage on the old oil, but it's been in there for over a year. That new synth stuff looks funny, kinda blue in color.
This morning I put all the plastic back on. Went well until I got to the belly pan, those mounts are a cross thread waiting to happen. Off course that happened. Now I have one threaded piece broken away from the sheet metal. Can get it tight, can't get it off. It'll just have to hold on with three bolts.
Fine German engineering!
  • Crossville, TN
Offline MIbrick
« Reply #2862 on: July 21, 2017, 12:01:26 PM »
I have the belly fairing on my 100RS. One of the pressed in nuts just spins. If I put lateral pressure on the allen wrench, I can get the bolt tight. But I'm sure one of these days that trick isn't going to work any longer.  Haven't formulated a plan of attack on how to fix it, although I did briefly consider just buying a new mounting plate.
  • Michigan
Offline BlitzenGruv
« Reply #2863 on: July 21, 2017, 02:40:23 PM »
Just got back from a ride out to my place of work. They had a fish fry today.
The bike ran well, but hot. It's 95 today, and even though the trip was only 10 miles that engine can cook my legs. Fan came on as soon as I entered my driveway.
I'll cool off a bit and go check the codes to see if it still thinks it can't read the bottom HES.
  • Crossville, TN
Offline drut
« Reply #2864 on: July 21, 2017, 03:02:52 PM »
    " It's 95 today,"
My RS cooks my legs at much above 70,thankfully most of the year in my area its much lower and the heating is welcome.
  • Newcastle upon Tyne UK
Offline gone_ape
« Reply #2865 on: July 22, 2017, 12:37:03 PM »
It's 102 and #HUMID here is Texas and frankly by the time I get two miles into the commute it's so uncomfortable at stop lights that motivation to ride is minimal...here's to a quick summer...(no offense you up north folks)
  • Austin, TX
« Reply #2866 on: July 22, 2017, 01:10:33 PM »
If your legs are cooking you could try making some reflective leggings to go over your boots but under your trousers. There is a double sided reflective insulation with a blue foam core.  Cut to size and shape, and attach with Velcro. I used it under my tank but would probably be worth a try in this application.
Offline BlitzenGruv
« Reply #2867 on: July 22, 2017, 01:12:38 PM »
1133 code is gone at last!
It was still there even after yesterday's ride.
Today I ran the fan test, AOK but the code was still there so I cranked the engine for about 10 seconds. Nothing but fours now.
  • Crossville, TN
« Reply #2868 on: July 22, 2017, 01:14:10 PM »
There's a document in the download section of k100 forum called Kbike heat management.  Download it and see what others have done to combat heat from the engine
Offline BlitzenGruv
« Reply #2869 on: July 22, 2017, 01:22:15 PM »
I hear that! Only bike I ever had which came close to this was my Triumph Trident. That thing cooked in traffic. But, it was air cooled.
  • Crossville, TN
Offline jakgieger
  • itinerant farmer
« Reply #2870 on: July 22, 2017, 08:58:31 PM »
Robert, I looked for the "download" section, etc., I found the write-up on your work (thank you), but no link or download.. :dunno2:
  • Kansas USA
  • 1989 K100rs se
« Reply #2871 on: July 22, 2017, 09:07:05 PM »
Jack it may be you have to reach a certain number of posts before the download section is available to you, check the regs. 10 posts is the number required if memory serves.
EDIT
This is from the K100 forum
Quote
he download page is password protected and only accessible to registered members.
Please DO NOT INCLUDE ANY LINK to this page into a post on the forum.
If you have a minimum of 10 posts AND an introduction ,to get the access password send a PM (personal message) to Crazy Frog (no Email please).
 Your request will be ignored if you don't have this minimum requirement!
Offline CNRED
« Reply #2872 on: July 23, 2017, 10:22:52 AM »
I removed my Fairing lowers, it looks a little diffrent, but not too bad, much cooler to ride.  I'll put them back on when  the temp returns to an exceptable level.
I'm pretty new to this bike, if there is a better way, I'm all ears...
  • Scottsdale, AZ
  • 1990 K75rt, 1992GSPD
« Reply #2873 on: July 23, 2017, 10:41:14 AM »
How about posting a picture of the transformation and an explanation of how long it took you to remove the lowers—just for the record and as a service to the general membership?
Offline BlitzenGruv
« Reply #2874 on: July 24, 2017, 01:10:35 AM »
I considered this. However, it looked as if the "kneepads" would have no support at the bottom and the radiator shroud would be hanging on by only two screws.
As expensive as these things were I'm surprised they didn't offer air conditioning as an option.
  • Crossville, TN
