Pick up your clutch parts from motobins.co.uk. Even with the shipping, still a lot cheaper.
Basically, you look for scoring in the pressure plates. If the clutch disc is very (well past service limit) worn, it is more likely that the plates are scored. The surfaces should be flat still. How many miles on the bike?
I replaced them all when I did a rebuild with a new engine. I tossed the ones from the 100k bike, worn to the rivets. I kept the ones from the 30k engine, which are fine (the rebuild started out as a clutch job, when I spotted a Craigslist motor and realized mine was failing, so I put the new clutch in the new engine). If you want, I could sell you the plates from the 30k engine cheaper than whatever is on ebay: just looking to get them to someone who would use them. The disk is probably fine, but I'd replace at least that anyways.
